how do you check to see if the injectors are working propporly?
Old Sep 21, 2003 | 07:12 PM
Makenzie71's Avatar
...94% correct.
title says it all...
Old Sep 21, 2003 | 07:15 PM
ERAUMAZDA's Avatar
with doctors ears. U should be able to hear them open and close.
Old Sep 21, 2003 | 07:25 PM
Makenzie71's Avatar
...94% correct.
even if the car isn't running?
Old Sep 21, 2003 | 07:26 PM
Makenzie71's Avatar
...94% correct.
Also, what exactly are the effects of running S4 injectors in an S5 without adapting them...just spliced in the connector?
Old Sep 21, 2003 | 07:34 PM
ERAUMAZDA's Avatar
if you don't have the right resistance you can burn the injector or ECU. Your best bet is to get them clean if you suspect that they are bad and there are a couple of threads on the forum that explain the difference between injectors.
Old Sep 21, 2003 | 07:36 PM
Makenzie71's Avatar
...94% correct.
I know the difference...that doesn't matter when you get a car and go to find out what's wrong and happen to notice that there are S4 injectors spliced in there...
Does anyone know how to test them? What voltage is required to open them up?
razorback's Avatar
You've Been Punk'd
i was just going to ask that question mckenzie.
well it was that and what is a good size of injector for a half bridgeport?
Old Sep 21, 2003 | 07:52 PM
Psychoblue23's Avatar
woa so you can really hear them open or was he ******* around??
Old Sep 21, 2003 | 08:10 PM
Project84's Avatar
Open up! Search Warrant!
yes, you can use a stethescope type thing to hear them click.
I have a S4 Resistor pack from a '86 GXL if anyone wants it. It worked fine but I got a Haltech so I don't have it or the stock wire harness.
Old Sep 21, 2003 | 08:23 PM
ERAUMAZDA's Avatar
I would use voltae because you can burn the injector. What you have to do is make a push button for it. Search the forum on that information.
