MY cas is spinning, my engine has good compression but no SPARK!!!!!!
Old Sep 21, 2003 | 12:25 PM
Peruvianrx7's Avatar
hey guys , i just checked the rotations on the engine and everything seems great. is a rebuild engine with 1200 miles on it. The CAS is rotating good but nO SPARK at all. any of you guys know where i could start checking>?? the car run fine but every now and then it would die out of nowhere meaning the spark was probably turning off or something. you guys have any ideas? i have the haynes manual so im gonna check it out. thanx guys.
Old Sep 21, 2003 | 03:21 PM
walken's Avatar
Registered Loser
check your CAS voltage, I unplugged mine, checked the voltage, it was there so I plugged it back in, then the car had spark.
Maybe its just a dirty connection.
Old Sep 21, 2003 | 03:25 PM
thanx what did u use to clean up all the conenctions? akso could it be the interlock switch that is connected on the front of teh throttle body?
Old Sep 21, 2003 | 03:34 PM
Aaron Cake's Avatar
Engine, Not Motor
How are you testing spark? Using a timing light is unreliable. Put a spark tester on the leading coil and crank the engine. Spark?
If not, them grap the Haynes or factory manual and measure for 12V at the leading. If you have a good 12V, then check the ignitor line for a series of pulses while you crank (scope is good for this). Pulses missing? Suspect the CAS or fuse.
Old Sep 21, 2003 | 03:47 PM
ERAUMAZDA's Avatar
ummm make sure he knows what you are talking about. 12v going in not voltage coming out Via spark wire line.
Old Sep 21, 2003 | 03:48 PM
Aaron Cake's Avatar
Engine, Not Motor
Hence my suggestion to "grap" the Haynes manual.
Old Sep 21, 2003 | 06:46 PM
can a fuse be bad without it being broken in half?
Old Sep 22, 2003 | 08:18 AM
Where is this ignitor line? and if the CAS rotates is that mean is in working condition? i can test the CAS voltage as well right? what about the main black fuse 80 amp, i replaced it with a new one a couple months ago? would the battery clamps have anything to do with it? what if the battery has lil to no charge would it still give me spark? anyway to check the battery? Does anyone know how i can narrow this down? it could be anything from the idle timing to maybe a ground somewhere in the car?
Old Sep 22, 2003 | 09:05 AM
ERAUMAZDA's Avatar
if your no getting a spark first check all connections and grounds.....Are u getting fuel also.
Old Sep 22, 2003 | 10:56 AM
evot23's Avatar
Classy
He has fuel. No spark on leading or trailings. Have yet to test volt as we had no volt meter at the time. You would have gotten spark since your battery was connected to mine on the initial test anyway. Battery clamps? No.
Old Sep 22, 2003 | 10:57 AM
it couldnt be the spark plugs either right eddie?
Old Sep 22, 2003 | 12:06 PM
Is your main engine harness ground connected? (under the UIM rear bolt).
where is that connected?
Old Sep 22, 2003 | 03:25 PM
evot23's Avatar
Classy
spark plugs are fine
Old Sep 22, 2003 | 08:23 PM
Please fellows, keep posting because I'm having a similar problem, except it's only clicking! The search goes on....
Old Sep 22, 2003 | 08:50 PM
yeah for real!!
Old Sep 22, 2003 | 11:36 PM
nestorx7's Avatar
i had the same problem once! i went to pick up my car at the body shop and it did not want to start! all my problem was a stupid fuse! check'em all out! buena suerte!!!!!!!!!
Old Sep 23, 2003 | 12:26 AM
ERAUMAZDA's Avatar
Well, Check for your grounds and Check that ECU agains Hans. Did you mount back the ECU under that panel back on? Or is it still dangling by the wires.
Check the fuses and check the grounds. Recheck the ground wire right under the UIM.
Hans..I really think your ECU is fired. Since I check the car out I suspected something like that. Your best bet is to just try! Just try another ECU it's nopt going to hurt if U do.
Your car died while you were driving...so something failed.
Remember We checked everything right after your rebuild..
The CAS
The ignitor
The relay
The grounds
So I narrow it down to 3 things
Your cabin fuses
Your ECU fried
You iginition switch.
Just to double check make sure your TPS is connected , your AFM is connected, and your boost sensor.
The ignition system is not complicated. People just over look a lot of things. The ignitors are pretty solid and the relay usually dies only by a blow to it with a shoot gun.
Also, be nice to your starter. if you keep cranking it...say bye bye to it.
Old Oct 5, 2003 | 01:50 PM
here is a lil upgrade.....
i bought a new battery.. new fuses.... i unbolted the traling coil w/ igniter i clean all the mother^&&(% connections and grounds... i check the voltage... everything was reading fine... i start the car and it starst right up.. it felt very powerful.... after being sitting there for over 2 weeks... anyways after 5 min the car dies.. and now it wont even turn over not even a sound just light up dashboard.....???
Old Oct 7, 2003 | 09:00 AM
the car started 2 days ago after i cleaned out the main ground for the fc under the coil igniter.. but after 5 minutes the car died again.. but now i dont even hear it crank.. all i hear is a tiny click when i turn the key.
.....COULD IT BE A LOOSE GROUND BY OR ON THE STARTER IT SELF? MY STARTER IS NOT MOUNTED PROPERLY SINCE ONE of the brackets that hold the starter is broken off and its only being hold by half of the bolt.. also the other side of the starter mount doesnt have the nut to hold it in place.. could it be the wires are a lil dirty and maybe since the starter is not mounted tight enough or properly that my car would die 5 min after start up? and that i dont even hear the engine crank at all? ( i say this because i have been trying to crank the car up so much maybe i fucked the strater in doing so )
Old Oct 7, 2003 | 10:46 AM
MAkE sure your fuses are good
Old Oct 7, 2003 | 10:53 AM
ALL FUSES ARE NEW... just replaced them 5 days ago.
Old Oct 7, 2003 | 10:07 PM
inside the car and in the engine bay....?
Old Oct 8, 2003 | 06:04 AM
evot23's Avatar
Classy
in the engine bay all new..checked and double checked. In the car...well there are only a couple to worry about. they are fine
Old Oct 8, 2003 | 07:44 AM
yeah the inside fuses all perfect. checked 3 times =)
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
