Taking off Oil Sending Unit to clean:...will it work better afterwards?
Old Sep 20, 2003 | 11:41 PM
areXseven's Avatar
il Cosa Nostra e vivo!!
From: Dove le cose sono fatte il vecchio moda il senso
My oil pressure marks above 80psi when the car is first started every morning. But then the engine warms-up and the oil pressure drops to almost zero at idle. Only marks 15 to 20 when driving in town.
I was thinking of taking off the Oil Sending Unit in the morning for a good cleaning. It's my first time in doing this. Thinking of just "flushing" it out and cleaning it thoroughly.
Q.) Will it work as good as a new one after the cleaning, i.e., produce constant accurate oil pressure?
Q.) Or should I just buy a new OEM unit from Malloy?
Has anyone ever attempted to clean their O/S/U, if so, what was the result. Thanks for looking.
Old Sep 21, 2003 | 01:49 AM
duboisr's Avatar
Try it but I will bet that it will not be work better . That is an educated quess . It will not take lone to clean so try it . After several days use let us know what you learned .If it works you saved some money . If not you will be good at changing the sender .hehehehehe
Old Sep 21, 2003 | 04:25 PM
FDjunkie's Avatar
The only thing that you can 'clean' on the oil sender is the flat spade for the connector. Therefore, there's little value in removing. FYI - it can be removed and installed without getting under the car, but it's sort of a pain.
Checking and/or cleaning the spade and its mating connector with spray contact cleaner won't hurt, but for my money you're most likely looking at a failing pressure sender. Of course I'm assuming you've already verified the oil weight and level, etc.
Least likely but possible is that your engine's thermal pellet has failed. If you're not familiar with this little guy, it's installed behind the bolt that holds the front pulley in place and is designed to 'leak' oil away from the rotors until the oil temperature climbs above 140 F; thereby giving faster warm-up, etc. Whatever you do, don't just pull the bult out without reading up on this procedure becuase you can easily damage your engine.
Old Sep 21, 2003 | 05:05 PM
areXseven's Avatar
I didn't get to take it off today, but glad I waited cause of your info. But doesn't the Unit have a connection, (probably the area that threads onto the engine..?) that allows oil to seep inside thereby allowing the unit to measure the pressure?? If so, then why wouldn't I be able to flush and clean it out. Thanks for you reply!!
Old Sep 21, 2003 | 07:18 PM
duboisr's Avatar
The thing threads into the block , take it out and you will see the hole in the stud ,spray that out with carb cleaner . Clean the electrical contact and reinstall . ( Then go get a new one . I am quessing, and am willing to bet you need a new one .If I am wrong I will pay for one of the shipping cost on one of Garfinkles torque braces, If you buy one .If I am correct what will you do for me that is fun ? )
Old Sep 21, 2003 | 09:57 PM
areXseven's Avatar
If you are right, I will sell my FD and give you half of the money. The selling price will be $100,000.00.
Old Sep 21, 2003 | 11:35 PM
duboisr's Avatar
That will be fun gool luck, I will be waiting to see if cleaning works . If it works turn the radio up and come get me for a ride .
