Oil leak and weird problems
Old Sep 18, 2003 | 11:27 AM
jonm16's Avatar
Unhappy Oil leak and weird problems
Hey guys I'm havin some problems. Ever since my engine flooded and I did the egi fuse trick and got my oil changed my car has been acting weird. I have a small oil leak some where in the front, my pressure seems kind of low(what should it be around 3000 rpm) and what should I do to fix this. Also my car smokes heavily for the first 1-3 min after startup then it goes away. I want to avoid an engine rebuild for now as I plan to rebuild it at the beginning of next year.
Please help
Jon
Old Sep 18, 2003 | 12:36 PM
twistedriver's Avatar
Finally I have LSD
Damn did you jack my car?? I have the same problem other than the smoke. Smoking is bad for you and very bad for your 7. Any ways if i were you i would just take the underbody panal off and see where is coming from. I am leaking from my oil coolet line and i am getting about 50 psi a 3000. I should be getting about 60 and up. I am going to change my oil line this weekend and change my thermo pellet, i hope that fix the problem. As for right now i don't dare to rev above 4000, but to be on the safe side.
alphawolff
Nov 17, 2015 05:57 PM
Cameron38
Aug 19, 2015 06:08 PM
sypath
Aug 16, 2015 12:06 AM
