Battery drain
Old Sep 17, 2003 | 10:07 PM
version13's Avatar
Exhaust leak
Battery drain
I have a really slow battery drain that drains about a third of my battery overnight, just low enough that i cant start it. I am almost certainly sure its my stereo. Is there a quick/easy way to check/fix this problem?
Old Sep 17, 2003 | 11:39 PM
Icemark's Avatar
get your digital multi-meter out and check to see what your draw is.
As covered in other threads before, you typically want to see less than a 70-75mA draw on a FC.
And (again as covered in countless other threads) once you see how much draw you have, then you can isolate the draw by pulling fuses and watching the draw change on your multi-meter.
Old Sep 18, 2003 | 12:15 AM
razorback's Avatar
You've Been Punk'd
i kinda have the same problem. believe my stereo is wired wrong. as in wired so that its on all the time. instead of when you turn the key.
Old Sep 18, 2003 | 12:27 AM
Icemark's Avatar
yep, that would be wrong
FC3S Timmy
16
Oct 3, 2015 01:08 AM
FC3S Timmy
Oct 2, 2015 08:08 AM
