What To Do For 18" Spare?
Old Sep 16, 2003 | 07:54 PM
jramosrx7's Avatar
I recently installed 18" CCW wheels on my car (with 285/30-18 tires), and would like to have a spare available for any long trips. Anyone out there come up with a solution for this?
Old Sep 16, 2003 | 08:17 PM
teamstealth's Avatar
Ozone Depleter
tire repair kit and some tire slime i dont think you'll be able to fit that 18" in the trunk
Old Sep 16, 2003 | 08:29 PM
Fumanchu's Avatar
Belligerent Security
AAA
Jramosrx7- I love Half Moon Bay area. I used to live in Santa Cruz for college. Me and the UCSC swim team used to go out there and camp all of the time. Plus I loved those roads for testing out my new motor mods
Old Sep 16, 2003 | 10:27 PM
Engberg's Avatar
The object of upgrading wheels is that you have a larger wheel with a smaller tire wall height. Basically you maintain a constant overall diameter. This also keeps you from screwing up your gas mileage, throwing off your odometer and speedometer, etc. etc. My guess is you have maintained that overall diameter and you can still use your stock spare tire.
Old Sep 16, 2003 | 10:36 PM
jramosrx7's Avatar
You know, you're right!!! The 285/30-18 is only very slightly different (forget which way) than the stock. I recall checking the speedometer error website and found them to very nearly the same.
Old Sep 17, 2003 | 12:21 AM
Little 7's Avatar
Why you take your FD for long trip?? You wanna to test your new twins?
Old Sep 17, 2003 | 04:27 AM
rynberg's Avatar
As others have pointed out, unless you have bigger brakes than stock, the OEM 16" spare is fine to use.
Old Sep 17, 2003 | 10:12 AM
jramosrx7's Avatar
Thought of that after I posted my reply, so went out to fit it. Doesn't fit on the fronts with the M2 Wilwood kit, but the rear is OK. Guess I'll carry the spare and a can of slime.
Old Sep 17, 2003 | 10:52 AM
saxyman990's Avatar
Place your ad here...
I think some of the newer JDM cars had a larger 17" spare due to upgraded brakes from the factory (pretty sure the Spirit R had them). You might want to talk to Jason at JT-Imports. He may be able to hook you up with one of these spares.
Old Sep 17, 2003 | 11:36 AM
rynberg's Avatar
SleepR1 has upgraded brakes and is purchasing this as his spare:
"FWIW, I plan to run a 17-inch mini spare combo thusly:
7 x 17, 35 mm offset Rage Euro http://www.discounttiredirect.com/d...CodeIndex=50490
205/40-17 Falken GR Beta FK-451 http://www.discounttiredirect.com/d...CodeIndex=28659 This size will fit in the spare tire well.
Recall that Type RS/RZ brakes requires 17-inch wheels, and thus the US-spec 16-inch mini-spare is useless to me..."
Old Sep 21, 2003 | 09:33 PM
impactwrench's Avatar
As one of the earier replys stated , the only thing that matters is o.d. But, look in your original car manual, do noy put the spare tire on the rear as it may destroy your rear end
Old Sep 21, 2003 | 09:54 PM
FormerPorscheGuy's Avatar
Yes it is for sale.
Easy, you get a AAA card and call for assistance when you get a flat. Remember your check book to because replacing a blown out 18" tire in the middle of no where America isn't cheep.
Old Sep 21, 2003 | 09:58 PM
Yes it is for sale.
One more thing you need to bring on a road trip is a tool kit. This can save your a$$.
Old Sep 21, 2003 | 10:03 PM
jramosrx7's Avatar
I have AAA, and I always carry a good toolkit. Just looking for a way to get on the road a bit quicker if needed.
Old Mar 1, 2008 | 03:54 PM
Julian's Avatar
The JDM 17" spare is very expense at apprx $700 imported. Other options are to look at spare wheels from other car companies. i.e. I have an Acura TL-S, its Brambo brakes are about same size as JDM '99 brakes.
It has a nice alumium (sorry not yellow) spare in size T145/70-17 (~ 25 in dia same as ours) with 45mm offset and 114.3x5 bolt pattern, so should fit, sorry i have not tried it yet, but it must be alot cheaper assuming you don't buy the car.
Coochas
44
Nov 5, 2019 11:08 PM
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
LongDuck
Oct 7, 2015 08:12 PM
Devon Murray
Sep 25, 2015 09:41 AM
