Tires pressure for track event
Old Sep 16, 2003 | 01:42 PM
cruiser's Avatar
What tyre pressure do you recommend for track event (road course) on tires:
- front : 225/50/16
- rear: 225/50/16
Thanks!
Old Sep 17, 2003 | 09:25 AM
redrotorR1's Avatar
LS6 Convert
What kind of tires? Street tires? R-compounds? Racing slicks? It makes a difference.
Old Sep 18, 2003 | 02:15 AM
cruiser's Avatar
Normal DOT street tires Dunlop SP9000.
Old Sep 18, 2003 | 10:17 AM
redrotorR1's Avatar
LS6 Convert
Probably start off with 33psi (F) and 30psi (R). With R-compounds or a stiffer sidewall tire, I'd go a little lower.
Old Sep 19, 2003 | 06:51 AM
cruiser's Avatar
Isn't 32psi stock ? Why would I want to go lower ?
Old Sep 19, 2003 | 09:43 AM
redrotorR1's Avatar
LS6 Convert
Your tires will heat up as you continue to lap the course. As they heat, the air pressures will rise. You want to start out lower so that they are at the right pressure as the tires get to operating temp.
Feffman
Midwest RX-7 Forum
Sep 1, 2015 07:30 AM
Feffman
Racing Kills Lounge
Aug 15, 2015 06:19 AM
