Do turbos spin @ idle?
Old Sep 24, 2001 | 06:49 PM
ThirdGenRX7's Avatar
Waiting
simple question
Old Sep 24, 2001 | 08:31 PM
bbr1's Avatar
Yes
Old Sep 25, 2001 | 10:40 AM
rx7tturbo's Avatar
It DOES???
I thought exhaust are only let into the turbo compressor to spin it up when throttle is applied? And if it does spin, I know for sure that secondary doesn't at idle.
Old Sep 25, 2001 | 11:07 AM
Bacon's Avatar
IRS 4 Life
TTT usto have a mpeg on his site..they barely moved at all at idle..but would spin when u reved it ....
if they do spin its not that much
Old Sep 25, 2001 | 11:57 AM
twinturboteddy's Avatar
Grumpy Lurker
If you have stock sequential turbos, you're primary turbo spins like mad at idle.
Like loose a finger if you touched it.
The secondary will not spin at idle. That's why the primary spins so fast is because it's getting ALL of the exhaust energy.
That mpg I made was with non-seq turbos where exhaust was distributed evenly to both turbos at idle which explained why they barely moved.
Old Sep 25, 2001 | 02:47 PM
Waiting
how about non sequentials?
Old Sep 25, 2001 | 02:57 PM
Poweraxel's Avatar
yes, the turbos are spinning all the time
Old Sep 25, 2001 | 04:09 PM
rx7tturbo's Avatar
the turboS??? meaning both the pri and sec, spinnning all the time??
Old Sep 25, 2001 | 10:30 PM
spooledUP7's Avatar
There and back again
It makes sense that the primary would be spinning while the secondary stood still because the waste gates normal position is open, while the prespool gate is normally closed.
Old Sep 25, 2001 | 10:40 PM
FD Racer's Avatar
sold the FD...kept the FB
The normal position for the wastegate, precontrol gate, and turbo control gate is closed for all three.
Right?
Old Sep 25, 2001 | 10:47 PM
spooledUP7's Avatar
The precontrol and turbo control are normally closed, but the wastegate is normally open.
Old Sep 25, 2001 | 11:28 PM
FD Racer's Avatar
I must disagree.
If the wastegate was normally open then it would take forever to build boost. The whole thing about good boost control is keeping the wastegate closed for as long as posible then opening it effectively enough not to spike.
Yeah?
Kyo
Apr 13, 2019 09:24 AM
incubuseva
14
Sep 3, 2015 12:37 PM
PhillyFC
Aug 21, 2015 06:36 PM
