First Gen RX7
Old Sep 12, 2003 | 06:37 PM
cberentsen's Avatar
General Yee
First Gen RX7
Im losing coolant, sometimes pressure back to overflow jar. No oil contamination in coolant, no water in oil, no coolant leaking on ground. Replaced water pump. Compression shows 100lbs at three cycles on each rotor.Cracked block?
Old Sep 12, 2003 | 06:43 PM
FB II's Avatar
well, let me be the first to say....Welcome to the rx7club! woooooooot! about your problem, have you recently done a coolant flush?
Old Sep 12, 2003 | 06:47 PM
FuLLsMoKe's Avatar
"By the beard of Zeus!"
Welcome
Are ya smokin white constantly (from exhaust)?
FS
Old Sep 12, 2003 | 07:04 PM
cberentsen's Avatar
General Yee
Did a coolant flush. Also, no white or blue smoke out the exhaust. Car runs great, just boils back through the radiator and calls for more coolant.
Old Sep 12, 2003 | 07:05 PM
inittab's Avatar
I read your email
Re: First Gen RX7
Welcome to the forum!
Do you have bubbles in the overflow tank? If so, I hate to be the bearer of bad news but that means that there's an 0-ring broken in the engine. Hopefully this is not the case because the only real way to fix it is an engine rebuild. But.... here's a page that describes a method for giving it a little more life. O-ring Fix. Good luck!
Old Sep 12, 2003 | 07:25 PM
cberentsen's Avatar
General Yee
Thanks!
I'm going to try it. Flush out the system several times with water, then flush w/degreaser, then add CRC Block Weld to the water and hope for the best.
CB
Old Sep 12, 2003 | 08:23 PM
Anex 570's Avatar
It Runs!
This actually sounds real simple. Just go buy a new radiator cap, try it. Get the one with the lever ontop. its like $3 at advanced or autozone. Try it and then do the flush cause that never hurts eaither.
Old Sep 12, 2003 | 09:05 PM
cberentsen's Avatar
General Yee
I'll do that and replace the thermostat, may as well they're dirt cheap.
Thanks all!
CB
Old Sep 12, 2003 | 09:23 PM
WackyRotary's Avatar
standard combustion
Sounds like the inner rotor housing o-ring/eqivilant to blowing a head gasket.
Darn sucks, had it happen once to me and a engine I got with a car I bought for cheap since it was that way.
If it starts to flood over the overflow bottle just starting it, forget about other fixes and take the engine out and fix it right. Inner housing seals are very important that they seal.
Old Sep 13, 2003 | 08:07 AM
inittab's Avatar
I read your email
Good advice!
wcr2k11
20B Forum
Oct 13, 2015 07:23 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
