Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Haltech questions???
Old Sep 11, 2003 | 02:02 PM
XSTransAm's Avatar
Ee / Cpe
Question Haltech questions???
Recently i put a haltech in my car... i have two questions.
Im about to put a 6 wire in the car to tune the fueling but i wanted to use the stock o2 sensor bung, does the haltech use the stock 1 wire o2 sensor to do anything???
also my smog pump isnt coming on.... if you had to guess, how long till my cat clogs? (im waiting on my midpipe)
Old Sep 11, 2003 | 04:23 PM
RETed's Avatar
The Haltech can use the O2 sensor to run closed loop, which is similar to how your stock ECU runs.&nbsp You can control it's function by adjusting turn on and turn off RPM's and load threshold, I think...
-Ted
Old Sep 11, 2003 | 05:59 PM
Project84's Avatar
Open up! Search Warrant!
The smog pump should be belt driven.
Old Sep 11, 2003 | 07:47 PM
XSTransAm's Avatar
Ee / Cpe
it is belt driven, but it needs to be turned on
(cant tell if your being sarcastic or not)
