Is this enough oil cooling for my 13bt, and road racing.
The car is a 82 FB
the engine is a 91 JDM 13bt, 60-1 to4b, tubular manifold
22x19x2 chevy racing radiator, 24x18x2 volvo intercooler,
I want to use two of these coolers:
http://store.summitracing.com/partde...rt=BMM%2D70266
one on each side of the front opening, using a GSL-SE air dam or a IMSA front air dam (if I can find one)
Ill be using 8an lines
I was planning on running them in series, with a thermostat between them so that one is always hooked up and the other comes on when needed.
I will be using the car on the street, along with some track days. and I plan on entering the 2004 Targa newfoundland. Which requires running the car hard for 10 to 20 min at a time.
What do you think
What do you think
Cool, someone else considering the Targa Newfoundland for 2004! I need to finish my car first....
I run the same cooler, but in the 11 x 11" size on my 13B NA. Running at the track on a 95F+ day, my oil temps would start to creep up to 220F after about 15 min of hard running. This was with no ducting at all, which should improve with the ducting I now have planned. If you run 2 of them, I'd put the thermostat before the first cooler. The Mocal t-stat I use provides about 10% flow through the cooler even when cold and then opens up as it gets hotter to full flow through the cooler. With cold oil, I don't think you will get much flow through the first cooler's small passages.
One problem I have had with the 11 x 11" cooler is the I have had 3 of them start to leak after a few months. I think this problem is only related to this size cooler because it is so long. I have it mounted in an aluminum frame that is rubber mounted to the car and I still have leaks.... :o( At least Racer Parts Wholesale has taken them back and replaced them.
ill be running 10-40, so I dont think flow is a huge problem. I would just like to know that one is dedicated in case I have a problem with the T stat.
if one is holding up for you in a NA then two should handle a turbo no problem, and mine will be ducted
I switch over to running synthetic 10W-30 to help the cooler live longer because I thought I had too much pressure (120psi @ 5000rpm).
If you really want a fool-proof system, check out the spec for that cooler that you have listed. Tru-Cool makes them for B&M and they have some kind of bypass built in for when the oil is thick and cold. I think the top and bottom rows have larger bypass passages in them. If it really works you would not need a t-stat.
I have trouble in cooler weather (below 65F) with the motor never getting warm enough, but that is probably more application dependent.
Oh, and I run a 6 qt. sump and the system holds about 10qts. Good for oil, but it gets expensive at oil change time
Also, you should run AN-10 lines and not -8's to give better flow and less pressure drop (even though the cooler is a bigger restriction).
I really dont thing that it has a built in bypass.
I would like to have 10An but the fitting are 1/2 npt on the cooler so whats the point.
Im still considering running two FC coolers. If I can find a place to mount them.
1/2 " NPT does not mean the internal thread size is 1/2" Take a look at a 1/2"-to-AN-10 fitting, there is no reduction in internal diameter. It is a straight through fitting. Check the ID of a 1/2" NPT and you will see.
FWIW-
A 1/2" NPT fitting is actually 3/4" diameter at the threads and is usually about 0.62" ID.
AN-10 ID is 0.625"
OK, you loose 0.005" ID, but it is better than AN-8 at 0.500" where you loose 0.125" ID.
AN-10 ID is 0.625"
Trending Topics
I think all the "AN" stuff you can buy from speed shops is actually a little smaller than regular hydraulic lines. When comparing a -8 "AN" hose to the Parker EZ-Flex hose I have the ID was visually larger on the Parker. I think the hose ends have about the same orifice size though.
could someone tell me the dimensions of the FC cooler.
I dont have access to one and I have to find a place to mount them before I try to buy them
Thanks
Thanks
I believe they are the same width as the 1st gen ones, which would make them as wide as the stock radiator in your 82. I'd guess about 2 inches thick and 5 inches high, but I don't feel like running outside to check right now.
If you want my opinion, the Mazda coolers are far superior to B&M coolers. RX-7 oil coolers are huge, very well made, relatively cheap and easy to come by, one should be enough for your car.
I believe the FC coolers are a couple/few inches longer than the gsl-se coolers. I'd like to see how you plan on mounting two of them in your FB, I don't have the space for one of them with the FMIC.
I have a couple of ideas.
If I went with one cooler. It would be flat against the belly pan with a scoop on the bottom of the car.
Not only would this cool oil but it would reduce front end lift a fractional amount.
If I went with two, well, I dont know, thats why I need the measurements.
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
