Boosting at only 0.5 BAR (sometimes?)
Old Sep 22, 2001 | 01:06 AM
RPW Motorsports's Avatar
Unhappy Boosting at only 0.5 BAR (sometimes?)
What the hell! I will be driving my car and sometimes it boosts fine and almost hits 1.0 BAR. Then sometimes I will hit it and only be boosting 0.5 BAR. But I can let off and hit it again and then it goes back to 1.0 BAR. What it causing this problem? Any ideas?
Thanks in advance
Mods listed below
Old Sep 22, 2001 | 02:38 AM
SPOautos's Avatar
Hey, where did my $$$ go?
What kind of computer upgrade do you have???? There isnt one listed in your sig.....you do know you should have one right?!?!?!?
Later,
Old Sep 22, 2001 | 02:55 AM
alwan16's Avatar
check all your ic hoses for splits that can open and close randomly with boost.
Old Sep 22, 2001 | 03:30 AM
Yeah, yeah I know I need a computer upgrade. In two weeks I am getting a M2 ECU upgrade. Should this fix the problem? Also sometimes the car feels like its hitting a rev limiter in 3rd at 6k rpm sometimes. ECU fix that too?
Thanks
Old Sep 22, 2001 | 04:03 AM
SPOautos's Avatar
your not hitting the rev limiter, your hitting the boost cut because your running WWWAAAYYYYY too much boost for the stock ecu. The stock ecu can only supply enough fuel for 10psi of boost......1 bar is 14.7!!!!!!
Your going to blow your motor if its not already hurt running that kind of boost
Old Sep 22, 2001 | 12:42 PM
spooledUP7's Avatar
There and back again
I agree with SPOautos. Even with my gutted precat and foam intake I have hit the Fuel cut. Not fun and not good. Upgrade that ECU ASAP and no more WOT boosting until then.
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
