a couple 13B swap questions
Old Sep 1, 2003 | 04:30 PM
The_7's Avatar
Registered Piston Eater
i am considering swaping a 13b into my 83 gs and giving it a half or full bridgeport. first of all, do i need a different tranny or will the 12A tranny fit on it? also, will a bridgeport 13B 6 port perform significantly different than a 4 port? if so, what are the differences? thanks.
Old Sep 1, 2003 | 04:36 PM
FuLLsMoKe's Avatar
"By the beard of Zeus!"
I'm pretty sure you'll need the 13b tranny... (not sure about this one)
But... for the diff between a 6 and 4 port... I don't think it'll make a bid difference. A bridge already has **** low end and that's what the 5th and 6th ports try to fix (in a stock port though). I don't see the 5th and 6th port heping much on a bridge.
FS
Old Sep 1, 2003 | 04:41 PM
The_7's Avatar
the reason i ask about the port differences is because its a lot easier and less expensive to get a 6 port 13B so i was wondering if there was a disadvantage
Old Sep 1, 2003 | 07:07 PM
REVHED's Avatar
Hunting Skylines
The 12A box will bolt up and work fine.
Stick to the 4-port engine if you want a bridge-port. The primaries on the 6-ports are tiny. You'll have more potential and better results with the 4-port.
Old Sep 1, 2003 | 07:11 PM
The_7's Avatar
oh...well, it looks like im gonna bridge my 12A then unless i can find a REALLY good deal on a 4 port 13B
Old Sep 1, 2003 | 07:51 PM
hornbm's Avatar
FD > FB > FC
actually you can just MAKE a 4 port 13b. A four port 13b can be made by changing the 12a rotors and rotor housing with 13b ones and keeping the 12a side plates. You'll need the 13b eccentric shaft too. Its pretty easy.
Oh and the deal with 6 ports are that its impossible to get any more than a very small street port out of a 6 port 13b.
Old Sep 1, 2003 | 08:00 PM
The_7's Avatar
COOL! is there any disadvantage of haveing the 12A end plates, etc. instead of the actual 13B?
Old Sep 1, 2003 | 08:01 PM
hornbm's Avatar
FD > FB > FC
nope, absolutely none.
Old Sep 1, 2003 | 10:14 PM
The_7's Avatar
sweet! how bout this...all 12A parts except a 13B e-shaft, TII rotor housings, and renesis rotors ?
Old Sep 1, 2003 | 10:24 PM
hornbm's Avatar
FD > FB > FC
now there is one part of this combo that I'm not sure about.
I dont remember if you can mix the 12a side plates with 86-95 rotor housings. The reason is because they moved the water jacket to the side plates from the rotor housings from 86 on. They changed it back on the renesis though.
All I'm saying is you're probably going to have to use GSL-SE housings and not FC ones. Oh yeah, and good luck finding counterweights for renesis rotors, LOL.
If somemone could confirm this please do.
Old Sep 1, 2003 | 10:33 PM
REVHED's Avatar
Hunting Skylines
Spot on. You can't mix the housings because they moved the water seal groove from the rotor housing to the side housing when the FC came out.
Old Sep 2, 2003 | 04:57 AM
1984special's Avatar
So little time and money
Do Renesis rotors fit? It'd be cool if they did! And where do you get them anyways? Motors are hard to come by because it's so new.
Old Sep 2, 2003 | 05:19 AM
rotary emotions's Avatar
HEAVY METAL THUNDER
Renesis engines will bolt on to old style tranny, but if the internals will be interchangeable....???
They might, but considering their price, I wouldn't really start experimenting The apex seals might work though, depending on the width.
As for the gearbox: 12A box will do.
So you'll need old-13B (pre 1986) housings, 13B rotors (some discussion on what-fits-what), and shaft. Depending on the shaft and rotors, you'll need the correct counterweight and flywheel.
Old Sep 2, 2003 | 12:14 PM
13B4port's Avatar
Will Work for Beer
i got a gsl-se engine that i'll part out for ya. eberything is i good shape except the rotors. one ofthem is trashed but the housing looks ok. pm me if you want anything ffrom the engine
Old Sep 2, 2003 | 02:34 PM
The_7's Avatar
i need 4 port housings because im doing a bridgeport. were there any 4 port 13Bs before 86 or was the se motor the first one?
Old Sep 2, 2003 | 03:23 PM
Yes, the RX-4 (not sure if all or just one trim level) and the REPU had 4-port 13Bs. The GSL-SE was the first FI 13B and it was 6-port, not 4-port. IIRC of course.
Old Sep 2, 2003 | 03:33 PM
The_7's Avatar
ok so i can use the 12A parts with rx4 or repu housings.....what about rotors? will all 13B rotors fit? which are the lightest?
Old Sep 2, 2003 | 03:49 PM
The lightest ones I think are 89-91 (S5) rotors? They're higher compression, and lighter. I'm not sure how to make them work in a pre-86 motor. On the Racing Beat Site, I think it says you need a 89-91 flywheel and counter-weight. Otherwise use the GSL-SE rotors. It also depends on cost.... do you want to throw a lot of money at this motor? Or are you like me, cheap bastard! (I'm a student, that's why)
Old Sep 2, 2003 | 04:33 PM
The_7's Avatar
yea im a student too (high school senior) .
but s5 ones sound nice, i think ill just save up for those.
i have been hopeing so badly lately that i would finish my car before i leave for college so i can have some fun and show it off before i leave but i dont know if thats gonna happen. if i can get a job and save money whereever i can i might be able to do it.
Old Sep 2, 2003 | 06:13 PM
hornbm's Avatar
FD > FB > FC
mabey i'm not to clear on this. Sorry If i confused you, the plain and simple way to do this.
I'm not sure about the renesis rotors but you can use any 13b rotors in any engine as long as you have the front and rear counterweights to match.
So for a not too costly solution (most bang for the buck) Heres the setup I would do. Start with your existing 12a side plates, and clean those up, get some GSL-SE rotor housings. Get some S4 rotors. The reason why I say S4 is beacause the S5 ones are a bitch and a half to find, because everybody wants them. They cost alot more, and the truth of the matter is that they give you about a 4hp gain over the S4 ones. Just use the S4 ones. Get the shaft from a GSL-SE while your at it, and get a rebuild kit. Also get the front counterweight form a S4 motor, and the stock flywheel too, so you wont need the rear counterweight. Bottom line, dont bother with RX-4 or REPU parts, your NEVER going to find them. You'll find cheap S5 rotors before you find that.
You should have a nice powerfull, inexpensive 13b 4 port after this. Port it as you please.
LOL, I was in the same boat you were too. I was a senior last year and had to get my 13b swap done before college. Just get a minimum wage job, and save your paychecks, its how I payed for my project.
Old Sep 2, 2003 | 08:51 PM
The_7's Avatar
i thought se housings were 6 port?
yea im still looking for a job, hopefully i get hired soon
Old Sep 2, 2003 | 11:11 PM
mwatson184's Avatar
holley guy
Or you could always buy a blown gsl-se motor, and port that one.
-Marques
Old Sep 2, 2003 | 11:28 PM
Confusing yes?
The rotor housing is where the rotor spins, and the only port on that is the exhaust port. The intake port (the one you bridge) is on the endplates / sideplates, which is where the 4-ports are! I hope that clears it up...
I'm going to college soon, so my GSL-SE is going to rest for a while But in the meanwhile I'm going to learn how to ride a motorcycle!
Old Sep 2, 2003 | 11:45 PM
hornbm's Avatar
FD > FB > FC
yeah I think thats where the confusion really is.
Old Sep 3, 2003 | 05:51 PM
The_7's Avatar
lol im dumb. if i wouldve stopped to think for a minute i wouldve realized that .
so i can use 12A parts with SE rotor housings, ANY 13B eshaft, and ANY 13B rotors? this might turn out to not be so expensive after all . i cant wait till i get get 650 dollars for a pineapple racing bridgeport
Id really like to learn too, i was thinking about getting a small one when i go to college next year but i dont think im going to be able to stop myself from putting 90 percent of my money into my 7
edit: also, what is a good price for 2 used SE rotor housings in good condition? id like to know around how much i need to save up before I post that i want them in the parts section.
Azevedo
26
Mar 1, 2019 09:19 PM
turbo-minivan
69
Feb 4, 2016 12:29 AM
Machupicchu
Aug 17, 2015 08:27 PM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
