what do yall fellas think of this setup
Old Aug 31, 2003 | 03:52 PM
ArticRX7's Avatar
She swallows
its an australian weber ida efi twin throttle body kit
Old Aug 31, 2003 | 03:54 PM
FuLLsMoKe's Avatar
"By the beard of Zeus!"
I've seen that one eBay... Someone posted that here. It looks great but I wonder how it performs...
FS
Old Aug 31, 2003 | 03:57 PM
ArticRX7's Avatar
She swallows
i have asked the seller how the performance is but i have not heard back yet...maybe on a business day i will
Old Aug 31, 2003 | 05:50 PM
AJC13B's Avatar
10.32 @ 133
They are standard fair on any n/a injected car here, no one really uses the holley type or any other type of inlet. Come in a range of sizes too, what size is for sale?
Old Aug 31, 2003 | 05:54 PM
REVHED's Avatar
Hunting Skylines
FS
Put it this way, it will **** on any carb setup you can think of.
Old Aug 31, 2003 | 10:10 PM
ArticRX7's Avatar
She swallows
i believe they had it in 48mm, 51mm and 55mm
Old Aug 31, 2003 | 10:13 PM
WanKeL FD RX-7's Avatar
Rotary addict since 86
what could be the performance output of these...
Old Aug 31, 2003 | 10:23 PM
AJC13B's Avatar
10.32 @ 133
48mm would be what you would want for a streetport, maybe a 51 for up to big bridge and 55mm for PP and turbo engines.
Ive seen up to 300+ from a well sorted n/a engine and well over 500hp from a turbo.
Basically all it is is 2 x 48mm holes with a throttle in the middle
Old Aug 31, 2003 | 10:28 PM
ArticRX7's Avatar
She swallows
while on the subject...to put this on the maf would be removed...what type of computer system would be best to tune and make up for the maf
Old Sep 1, 2003 | 12:05 AM
S2-13BT's Avatar
Any aftermarket ECU from Microtech to Motec would do fine. They'll run a MAP sensor. As for which is best... Well, that's a matter of personal preference mostly (unless you can afford Motec). Basically whatever your tuner is most comfortable with and uses the most.
My brother will be using one a 13B bridgy using a Microtech MT4, and hopes for some decent numbers for a street car. Not sure exactly what numbers though.
eplusz
15
Oct 7, 2015 04:04 PM
FC3S Timmy
Oct 2, 2015 08:08 AM
