Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
BRE parts.. or similar..
Old Aug 28, 2003 | 11:39 PM
PPC-Racing's Avatar
took my BRE apart, one rotor and housing is pristine, perfect even.. the other.. I've never seen one so chewed up in my life! however the important end housings are untouched..
What i'm looking at is either the REW or BT rotors, which is the closest fit to the BRE? also the housings, which would be better given the rather large ports on the BRE ? REW or BT ? I'm angling towards the BT rotors in REW housings with the BRE end/center plates ?? any thoughts on this ?
oh and for those with BRE's what rebuild kits did you get ? BT or REW?
Old Aug 29, 2003 | 11:50 PM
streetpower's Avatar
bt rotors in rew housings and gre plates is a good set up use the bre e-shaft with counterweights and match the rotor balance codes......
reuse as much bre parts as much as possible ...
buy cosmo lower and upper intake gaskets ...buy 87 na engine rebuild kit for viton coolant seals etc
i thought you had a running motor?
Old Sep 3, 2003 | 10:56 AM
PPC-Racing's Avatar
I do have a running motor , it's in the car right now running around quite happily.. THiers a TII at the junkyard that I'm going after today.. I'm going to take the shortblock and tranny with the 5spd parts for ta conversion.. hopefully the yard doesn't try to bend me over for it.
which counterweights I've got S5 NA and bre weights.
i checked out the rotors after I cleaned off the carbon build up and as it turns out both are useable.. the blown one has a small little dint @ 1mm deep outside the main combustion area but other then that it loks good.
Old May 3, 2007 | 09:19 PM
VaGambler's Avatar
just wondering if you happen to have any extra BRE parts , ?Im looking for the elbow off the TB ..Please pm me if you can help
Thanks in advance
p4nc7
Dec 9, 2005 09:57 PM
apexwarrior
NE RX-7 Forum
Jul 5, 2005 01:22 AM
rotarynemesis
Old School and Other Rotary
Mar 25, 2005 01:41 AM
jacobcartmill
14
Dec 30, 2002 06:32 PM
