Fd Mods...
Old Aug 27, 2003 | 03:38 AM
kamaal27's Avatar
Fd Mods...
how much boost can you push on a stock ecu..if i have a hks intake, dp,mp, exhaust, BOV, blitz dual boost controller, would i overboost my motor resulting in blowing it up..how much modifications can one do before it needs to get a aftermarket ECU.. do you guys think with the mods listed above do i need an aftermarket ECU or anything else to help balance my air fuel ratio......
Old Aug 27, 2003 | 03:53 AM
rynberg's Avatar
You cannot go over 10 psi with the stock ecu. You should not run a midpipe on the stock ecu (even though some people do, but they're playing russian roulette everytime they drive..).
No offense but these basic questions have been discussed countless times. Please read through the 3rd gen forum and use the search function.
Old Aug 27, 2003 | 02:17 PM
Dougie_fresh_007's Avatar
i ran 12 psi on my rx6b... .... but as i have alwayz said... im special
Old Aug 27, 2003 | 06:07 PM
BoOsTin FD's Avatar
Powered by** Rotary
All cars are different. Some people have been able to run 12 psi on stock ecu safely, but since you are going with an open exhaust there is a chance to have a boost spike, which can blow up your engine.
I think it would be best to get an ecu if you are planing to run over 10 psi.
Old Aug 28, 2003 | 07:42 PM
astrochild7's Avatar
controlled kaos
atleast get a fuel controller with 720's and fcd other wise you will blow you motor asap.
Old Aug 28, 2003 | 10:54 PM
rynberg's Avatar
Those kind of mods don't work on an FD. You FC guys have it easy!
rotor_veux
46
Jun 12, 2018 10:39 AM
HellRotary
RX-7 Audio/Visual Lounge
Jun 18, 2006 04:55 PM
2xrx7
Jun 18, 2006 01:40 AM
Dougster
Jun 17, 2006 11:47 AM
jpandes
37
Apr 19, 2002 02:36 PM
