Haunted Headlights
Old Aug 27, 2003 | 03:16 AM
1979silver's Avatar
Haunted Headlights
When my 1979 is in the garage I can activate the manual headlamp switch and both headlamps pop up and stay up. Same thing with the headlight stalk. When driving, the left headlamp will pump up and down and never lock in position. Does this sound like an electrical or mechanical issue? The left headlight dips slightly before locking into place. Thanks BLH
Old Aug 27, 2003 | 04:03 AM
Pedestrian X's Avatar
SpAz!
got a video of it? ya know.. just for ***** and giggles :]
Old Aug 27, 2003 | 06:12 AM
silver79's Avatar
The problem is I can't drive at night until the problem is identified and corrected. Its the only thing wrong and the car is 24 yesrs old. Amazing. Not like that MG I used to own.
Old Aug 27, 2003 | 07:58 AM
pillage6's Avatar
Is the bar that connects the motor to the headlight on right?
Old Aug 27, 2003 | 10:55 AM
thorin's Avatar
buy a haynes manuel. it shows you how to manully "twist" the headlights up. i had to do that once. it turned out that the connecting bar fell off, and needed to be reattatched though
Old Aug 27, 2003 | 11:28 AM
The_7's Avatar
Registered Piston Eater
the headlight demons are mad at you
have you checked the wiring? its possible that the wiring for the left headlight is loose and everytime it gets disconnected and reconnected it goes up and down
Old Nov 20, 2003 | 01:03 AM
silver79's Avatar
Turned out to be a short in the motor. Bought new motor from dealer, almost $300.00 for parts alone.
renjiv2
57
Jan 25, 2024 03:34 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
