Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
OMP controll
Old Aug 26, 2003 | 02:44 AM
PPC-Racing's Avatar
OMP controll
I have a 13BRE, regardless of what engine it is, do any of these standalones control the OMP system, and if so has anyone done it with a BRE yet? given that's it's MUCH larger and only has two ports into the housings and none to the intake runners.. I'd like to get this working. 7stock this year it was pointed out just how poorly premix actually works. I'd like to avoid a premature rebuild.
Old Aug 27, 2003 | 10:09 AM
ZeroBanger's Avatar
you can adjust the OMP as to how much oil is injected with the power fc. dont ask me how, my tuner does all that crap for me.
Old Aug 27, 2003 | 12:57 PM
DCrosby's Avatar
No it's not Turbo'd
There is a Map in the AEM that lets you map OMP Duty against Mass Air Flow ... i think... anyhow there are several settings for the OMP and they work a bit to well on the basemap... 2Qts of oil Per Fillup of Gas....
I still ned to adjust them... according to sources a "7" should run 1 qt. per 2-3K Miles or Per Oil Change...
-DC
Old Sep 12, 2003 | 01:18 PM
sbaker25's Avatar
Re: OMP controll
Can you detail what it was that was pointed out that shows how poorly premix works? Strangely, all the professional race teams (that I know about) that run rotary use premix.
Old Sep 19, 2003 | 10:15 PM
CrazyRoller's Avatar
someone told me to Disable OMP and run REMIX
anyone care to enlighten me on how to do that..
oh yea
and tell me what exactly what that is
(im learning)
Old Sep 19, 2003 | 10:48 PM
ok
how do i disable the oil metering pump?
what does the oil metering pump do?
what are the benifits of premixing?
what should i use as a premix?
Old Sep 21, 2003 | 02:31 AM
rynberg's Avatar
If you don't know what the oil metering pump does, I don't suggest disabling it.....
FYI, the OMP supplies oil to the internal parts of the rotary engine. Pre-mixing is adding 2-stroke oil to your gas tank to lubricate the internal engine parts that way. Personally, I would rather rely on the time-tested method that Mazda came up with.....
Old Sep 21, 2003 | 06:35 AM
RETed's Avatar
Re: OMP controll
Yeah, I'd like to hear where exactly this came from and what exactly they said?&nbsp Sounds like BS to me...
-Ted
Old Sep 21, 2003 | 05:11 PM
Black13B's Avatar
In Full Autist Cosplay
Oh boy, another premix thread, with Ted! Sweet.
Over winter my GXL will be premix only, no MOP.
There are a few canadian guys who run premix (only, no MOP at all), PPC-Racing. Next meet you should make sure to bring it up into discussion with them! It's very enlightening.
Infact, the Mazdee's (sponsored) AE86 has a N/A Carbed 13B. It was at driftnation show in Brampton. I got a good look at the motor, they are premixing as well. The Mazdee's guys have alot of experience and knowledge under their belt. I don't think they'd jump into it headfirst with no knowledge on the topic.
Good discussion here:
https://www.rx7club.com/forum/showth...threadid=64310
20B Forum
21
Mar 22, 2022 01:00 PM
cewrx7r1
15
Aug 6, 2018 11:41 AM
