I have a few questions about what I'm fixing
Ok I've done some work so far, and I still have quite a bit to go. One thing I have to do is get new mounts for my oil cooler, fix the exaust, drop the transmission to replace the release bearing pressure plate ect. I'm gonna get everything at once for the clutch. My question is where can I find the mounts for the oil cooler, and if i get a new header, what happens to the smog control stuff(the hose conected to the stock header, and all the other things that dont hook up to a new header). I'm looking to get the Monza parts in Victoria British and i need a new Cat too. Its almost feeling like a complete car now, how about some confidence of how easily this will go. Prolly the biggest problem is the clutch, it will not realease.
Thanks
Jamy
Thanks
Jamy
first of all, DO NOT go with monza exhaust. Racing Beat is you only choice. If you must have a cat, mazdatrix sells a racing beat header/aftermarket cat combo that would allow you to retain all of you emissions devices and would flow nearly as well as a presilencer (or so they say). This is the setup i am currently in the process of getting.
Re: I have a few questions about what I'm fixing
Originally posted by Anex 570
...... where can I find the mounts for the oil cooler
Racing Beat is NOT the only choice. I have heard very good things about Mindtrain's exhaust. Do yourself a favor and contact the folks as www.kickyride.com they can tell you all about it.
rgordon1979
40
Mar 15, 2022 12:04 PM
Devon300zx
15
Sep 16, 2015 06:57 AM
Nosferatu
Sep 5, 2015 02:13 PM
gabescanlon
Sep 5, 2015 12:04 AM
