Oil restrictor on my SR stage 2 setup?
Old Aug 23, 2003 | 07:29 PM
pp13bnos's Avatar
Pineapple Racer
Hey guys, I recently picked up a SR stage 2 turbo/XS cast manifold. What I'm doing is running a -6 SS line from the place where the stock banjo bolt/line hooks up to the motor, to the turbo. What I'm wondering is, how did you guys go about restircting the oil, and how much did you restrict it? Thanks, CJ
Old Aug 23, 2003 | 07:47 PM
setzep's Avatar
I restricted mine by drilling and tapping the fitting on the turbo. Drilled to 1/4", used a 1/8th npt tap then got a hand full of 1/8"npt socket head pipe plugs and driled them to various sizes, .040, .060, .070 and .080. I've been told that most turbos need to be rescricted to .060-.080". I am running the .080" with no "backing up" of the 5/8" turbo drain yet.
hope that gives you an idea.
Old Aug 23, 2003 | 08:44 PM
88fc3sw/HX83's Avatar
CJ,
According to ErnieT, you DON'T want to restrict the oil feed line to the turbo. He did that and ended up rebuilding it soon afterwards. Jut run that -6AN fitting from the block to the turbo. Just make sure you run atleast a -10AN for the drain, any restriction on the drain will result in "puddling" and it will cause oil to seep through the seals.
Jim
Old Aug 24, 2003 | 09:58 AM
setzep's Avatar
Well there you go I guess those turbos don't need to be restricted.
Old Aug 24, 2003 | 07:43 PM
pp13bnos's Avatar
Pineapple Racer
Hey Jim, I need to swap oil lines with you You gave me a -8 on accident. I'm in no hurry, as I'm still banging the frame rail in. CJ
Old Aug 25, 2003 | 12:27 AM
CJ,
The Big hose is only a -8AN? Then I guess I don't know my hose sizes, I was told that it was a -10AN
Old Aug 25, 2003 | 04:37 PM
setzep's Avatar
What size wrench fits on the fitting? a 7/8" or a 1". 7/8"= -8 and 1"= -10
Old Aug 25, 2003 | 05:06 PM
setzep's Avatar
oops, double post
Old Aug 25, 2003 | 09:13 PM
pp13bnos's Avatar
Pineapple Racer
The big hose you have me is a -8, but the fitting on the turbo is a -10. I don't suppose you have the right one laying around do you? CJ
Old Aug 25, 2003 | 11:59 PM
CJ,
That's the one Derrick made for me, I was under the impression it was a -10AN because I have -8AN fuel lines and they're smaller than the drain.
Old Aug 27, 2003 | 05:36 PM
CJ,
YOU'RE RIGHT!! I did give you the WRONG hose.
sYnth.
Aug 19, 2015 06:27 PM
