Widest rear tire size for stock rims
Old Aug 19, 2003 | 12:15 PM
Godzilla-T78's Avatar
Whats the widest tire I can run on a stock rim. I have my car lowered. Its currently running 245>45>16 and with my t78 I just burn the hell out of my proxies everytime I get on it.
Old Aug 19, 2003 | 12:21 PM
rynberg's Avatar
245/45 is the biggest size you should run on the stock rims. I know that for drag racing only, you can 255/60s (BFGs).
Looks like you need to move up to some wider wheels to support larger tires.
If your car is not a daily driver and never sees rain, you almost might want to consider running Toyo RA-1 or Yokohama A032R tires in the 245/45 size.
Old Aug 19, 2003 | 01:01 PM
skunks's Avatar
I'm a CF and poop smith
you would be suprise at what you can strech on a tire, in anycase, wider is not always better. Its all about tire compound. If you want grip, get slicks.
Old Aug 19, 2003 | 05:32 PM
HeatTreated's Avatar
Hi Powr FD's
For a good priced regular street tire.
You can get Yokohama ES100s in 245/45/16's
A great tire for under $100 each!
Old Aug 19, 2003 | 06:29 PM
redrotorR1's Avatar
LS6 Convert
A 265/45 16 will fit on an 8" rim .... barely. It will look like a cantilever tire. Whether or not the tire will still fit in the rear wheel well is another question. I doubt it.
Old Aug 19, 2003 | 09:22 PM
my previous fd I had 285s on the rear with 18x10s so I dont think the wheel well will be a problem.
Old Aug 20, 2003 | 03:00 AM
redrotorR1's Avatar
LS6 Convert
It's not the wheel well that's the problem. If you still have stock diameter springs and the stock trailing arms, I can almost guarantee that any "over-sized" fitment will not work. 2.5" ID springs are almost a requirement to fit any of the BIG tires.
Frisky Arab
13
Aug 18, 2015 05:30 PM
FD7KiD
Aug 17, 2015 11:50 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
