Can stock apex seals on a Non-turbo handle boost?
Old Aug 12, 2003 | 01:26 AM
JDriftM's Avatar
Progressive Rotorhead
Can stock NA apex seals handle a HKS GT2835R or GT-RS turbo on a custom manifold(internal wastegate), HKS Dual HiPower Exhaust, HKS Super MegaFlow Intake, HKS Front Mount IC, running just enough boost to hit 350hp? If this set-up would work would it still work or work better with a 13BREW 3rd Gen intake manifold?
Thanks,
Mini me
Old Aug 12, 2003 | 02:15 AM
REVHED's Avatar
Hunting Skylines
There's no such thing as turbo and non-turbo apex seals.
- 1974 = 6mm two-piece carbon
1974 - 1985 = 3mm two-piece steel
1986 + = 2mm three-piece steel
The same seals were used in all cars from each time period.
Old Aug 12, 2003 | 01:40 PM
Jeff20B's Avatar
Lapping = Fapping
I noticed a typo
Old Aug 12, 2003 | 02:35 PM
JDriftM's Avatar
Sorry about that, but would the set-up(s) I have be okay on stock seals?
Thanks,
Mini me
Old Aug 17, 2003 | 12:19 AM
Carl Byck's Avatar
Mad Man
FWIW, the 2835s come alive above 20-25 psi, if you want 350rwhp, go with a 60-1 for 600.00.
Old Aug 17, 2003 | 12:00 PM
now's Avatar
now
just a correction the carbon seals were a one piece
matt
Old Aug 17, 2003 | 06:49 PM
REVHED's Avatar
Hunting Skylines
matt
You're right I meant to say one-piece. That's not entirely correct though. Mazda actually produced a two-piece 6mm carbon and different spring that were used on some automatic 10A's. Very rare though.
Old Aug 18, 2003 | 12:55 PM
praveen's Avatar
i put in standard rotors/housings and am usiing a big single turbo instead of the twin////is the extra boost gonna damamge my standard engine parts?
do i need special rotors, seals etc?
pls help
Th0m4s
Feb 26, 2019 02:04 AM
sYnth.
Aug 19, 2015 06:27 PM
