clutch went out damit
Old Aug 10, 2003 | 01:33 AM
hey hows it goin? ive notice a problem with my freakin clutch in my car for the past week. when i get in the car i start it up and it starts fine and everything but i have to pump the clutch a bunch of times to get it to work.. today it finally took a ****.. me and my buddy bled the lines and there was a **** load of air bubbles commin out as we were bleeding it we almost went through the whole master cylinder thingy that holds the oil and it still freaking stays on the ground when u push it down..pluns that thing that u put the oil in for the clutch fluid seems to be loose not tight like the brack fluid tank. i dono if anyone has had this happen b4 but i would like some info if ya can!
thanks
Dave--
Old Aug 10, 2003 | 01:37 AM
sounds like the clutch slave.... that thing on the tranny......
when it sticks its the hydralics... meaning master cylinder or slave cylinder.....
but I vote replace the slave for 20 bux......... if that dont work, then its the master cylinder.....
peace
Old Aug 10, 2003 | 01:45 AM
is it reachable or do uhave to tear a bunch of stuff out to do it?
Old Aug 10, 2003 | 02:18 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
Nah it's just 2 bolts holding it to the tranny. Follow the line from the master cyl to the slave to find it. Remove it, get a new one, slap it back on there and bleed the system. I did it in less than a half hour.
Old Aug 10, 2003 | 02:34 AM
faye x7's Avatar
brilliantly stupid
Yeah, my slave is leaking...need to replace it. I think i'll just replace the master and slave.
I've never did bleed a system before, is it pretty easy?
Old Aug 10, 2003 | 11:31 AM
yah me and my buddy did it yesterday it was pretty easy but i hope i dont need to replace me slave thing mabye all it needs is a good full bleedin!! yehh ha
dave--
Snoopy FD
Oct 13, 2016 06:12 AM
risingsunroof82
Sep 9, 2015 08:06 PM
