mmhg to psi
Old Sep 17, 2001 | 10:14 PM
snoopster76's Avatar
Twisted Girl Chaser
mmhg to psi
what formula do you use to convert this, I'm sure I could figure it out, but someone should already have it.
Old Sep 17, 2001 | 10:21 PM
RestoTII's Avatar
1 mmhg = 1 torr
760 torr = 1 atm
14.7 psi = 1 atm
so 760 / 14.7 mmhg = 1 psi
ends up around 50.701
Old Sep 17, 2001 | 10:30 PM
Twisted Girl Chaser
correct me if i'm wrong
stock guage reads 400mmgh which is about 27.?? psi
Old Sep 18, 2001 | 12:48 AM
Scott 89t2's Avatar
SOLD THE RX-7!
1 psi is 51.71493 mmgh
umm, 400/50 is 8... not 27
but I wouldn't trust the stock gauge to much.
Old Sep 18, 2001 | 06:26 AM
Twisted Girl Chaser
figure that out after a bit
That what i was coming up with later on, thanks for the info. You guys always have good info. So that means with a stock TII, I should be at least 2/3 the way up the stock guage, if it were working properly? I should be getting my aftermarket boost guage in the mail soon, I was just wondering about it now.
Old Sep 18, 2001 | 06:38 AM
The Ace's Avatar
Greek Power
Talking
My stock gauge reads max. 45, which is 0,45bar. TII has max. 0,35bar stock, so your gauge should never go above the 3/4 of the gauge (above 0 of course). If you start modifying your engine, then with DP, catback and TID/intake, you could probably see even above the 0,45bar (close to 0,5bar), but then you should get yourself an FCD or something similar to control overboost...
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
LongDuck
Oct 7, 2015 08:12 PM
