Sponsored by: CARiD
Apex seal and ECu questions
Old Aug 9, 2003 | 10:26 AM
fd3typer2's Avatar
Hi guys,
I bought apex seals for my first rebuild which was about 2 months ago. They were 1 piece items which seemed strange to me because I thought they should be in 3 pieces.
I just broke 2 seals which I think is down to my stupidity, increasing boost with no ECU change.
Now inspecting them, they fractured along the line where usually the 2 long pieces meet. I will have a picture of this on Monday because my explanation is not clear.
Do you think the break is due to this being a bad/poor quality apex seal, or more likely due to detonation.
Secondly,
So far, I have a downpipe, decat, free flow back box, cold air induction kit. Hopefully an intercooler soon.
ECU wise what should I do, considering the following points..
I am in Mauritius where we have no Dynos
The limit of my mods should be the above.
Will I be able to make use of the PowerFC if I have no Dyno facilities available? And can I use something like a GTechPro unit to try anything (I know, it's a bad way to go but have not got much choice.. :-) ). As far as downloaded maps go, can I get hold of one from someone with a similar setup and expect this to be ok? Will the GTechPro or Geez be able to give me info on this?
Or can I get a pettit ECU and be pretty safe. And how far can I go mod wise if I change my mind..?
Also off the subject ... With my set up, what BHP should I be expecting??
Thanks .
Trevor
FD3S 1994 Japan Type R2
Old Aug 12, 2003 | 01:07 AM
Project84's Avatar
Open up! Search Warrant!
Which rotor were the seals on tht broke? I don't know if the 3rd gen RX-7 is like the 2nd gen, but on the 2nd gen, once you boost to 8.6psi, fuel is cut to the rear rotor. If you try to go above that without a fuel cut defencer, then problems such as detonation may occur.
Old Aug 15, 2003 | 12:50 PM
Keisuke T.'s Avatar
If you are running a full exhaust on an FD with the stock ECU and intercooler you probably detonated very badly. Yes you can tune the Power FC on the street with no dyno. With a full exhaust and intake with stock intercooler and regulated to 10 psi (safe) you can expect about 270 hp to the rear wheels. Good luck.
Snoopy FD
Dec 8, 2015 01:45 PM
VTECthis
Aug 24, 2015 09:01 PM
sYnth.
Aug 19, 2015 06:27 PM
