not your usual Q on Konis...
Old Aug 4, 2003 | 02:00 PM
alberto_mg's Avatar
This is on my recently acquired 93 Touring running Konis with stock springs and sways.
2 questions:
1. Take a look at the pics and tell me which one is the correctly installed Koni. The previous owner made a mistake one lower spring perch is installed one way and another is installed reversed.
As a result, the ride height is also off by 1/2" side to side. Which brings me to my next question.
2. Which perch should I set the Konis? Ride height is 26" from floor to top of wheel well on passenger side. It is 26 1/2" on driver side. What is the 'correct' ride height for a car running Konis with stock springs and stock wheels with 245/45 Kumho 712? Yes it was measured on a flat surface.
I have 2" of clearance between the top of the tire and the wheel well lip. I'd like to decrease that slightly if I could. Car looks all jacked up right now.
Thanks for your help.
Here is the driver side pic:
Old Aug 4, 2003 | 02:07 PM
alberto_mg's Avatar
Damn board! Click this link for pics please http://www.b2t2.com/rx7/
Thanks.
Old Aug 4, 2003 | 03:15 PM
jr426's Avatar
The driver side is wrong. If you have 3 grooves on the shock than the highest is stock, mid aprox 1/4" and lowest aprox 1/2" drop. BTW, I don't think there are many RX7s that set perfectly level side to side.
Old Aug 4, 2003 | 03:31 PM
DamonB's Avatar
Everything here is right on, and my car also doesn't sit level when measured side to side. I think my ride height was almost 1/2" different on either side with the perches at the stock height.
alberto_mg's Avatar
Yeah, that is the part that is puzzling me the most. I don't know if you can tell in the pic, but it is on the lowest groove right now.
If I look this jacked up on the lowest setting with 2" of clearance between the tire and fender and 26" to the wheel well, how ridiculously high is it going to be on the highest setting?
From what I've read people say to set the perches on the high setting to retain stock ride height and clearance issues with the fender liner, but there is no a stock 7 is higher than mine right now.
Can someone with a similar configuration please measure their ride height from ground to the middle of the wheel well opening? I'm curious what others are running.
Thanks.
Old Aug 4, 2003 | 03:33 PM
alberto_mg's Avatar
Can't be. Check the pics. One of the perches is definitely reversed.
Old Aug 4, 2003 | 03:35 PM
ptrhahn's Avatar
Never mind the grooves, one perch (the first one) is upside down!!
w/ stock springs, i'd prolly run the fronts on the middle groove, and the backs on the lowest groove... just like i did my eibachs... maybe even both on the lower.
the upper is stock height.
Old Aug 4, 2003 | 03:44 PM
alberto_mg's Avatar
OK the perch on the driver's side is reversed! I'll be fixing that.
I was thinking of that too (running on the middle groove), but I want to get a base line so I don't wind up *too* low. Right now I definitely have clearance to lower 1/2-1" up front.
Can anyone out there hook me up with ride height measurements so that I have a basis of comparison please?
Thanks.
Old Aug 4, 2003 | 04:18 PM
ptrhahn's Avatar
per the factory manual, as long as the rear fender lip is higher than the front, you're cool... you prolly want em fairly close to each other.... and the lower koni perches lower the car approx. 3/4" each.
Old Aug 4, 2003 | 05:04 PM
DamonB's Avatar
Everything here is right on, and my car also doesn't sit level when measured side to side. I think my ride height was almost 1/2" different on either side with the perches at the stock height.[/B]
I meant everything was right on with the answer that jr426 gave.
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
Robrods64
Oct 2, 2015 07:56 PM
TrboMike
NE RX-7 Forum
Sep 28, 2015 09:40 PM
