I finally got my own RX-7
Old Aug 2, 2003 | 01:19 PM
Anex 570's Avatar
It Runs!
I finally got a 1979 RX-7 with 5 speed and sunroof. I got it for free from my aunt. OK to start it has no battery because they took it out when it sat so long. You can't push the clutch pedal in. They said it ran when they last parked it, and it hasnt lost any oil, coolant, nor gas. I'm going to drain everything and get a battery. If anyone has any other sugestions what I should do, let em rip. Oh yea, my cousin painted it silver and maroon, its a classic looking car hehe.
Old Aug 2, 2003 | 01:21 PM
nickj's Avatar
Sounds like a lot of fun, getting it running and all. You can't push the clutch pedal in? That's kind of important, isn't it?
Old Aug 2, 2003 | 01:50 PM
rlking's Avatar
when you start it up the clutch will break loose
Old Aug 4, 2003 | 11:22 AM
Anex 570's Avatar
It Runs!
Well dont you have to push the clutch in, just to start the car?... I also dont have a battery holder, and suggestions?
Old Aug 4, 2003 | 11:27 AM
Bungee cord for the battery.no the clutch doesn't need to be 'in'to start the engine. there is fluid in the clutch master ??
Old Aug 4, 2003 | 11:30 AM
pratch's Avatar
Mazspeed.com
You can start it without the pedal pushed in - provided that you're out of gear. Check to make sure the clutch slave cylinder is in fact located where it should be on top of the tranny bellhousing. If you can't push it at all - it might be wedged. Additionally the clutch fork (rod from the pedal to the clutch master cylinder) might be askew and need to be put back into its place.
Definitely get new gasoline. Mine sat for 4 years and had a nasty coat of varnish in the tank when I went to get it going again. Not sure if the 79 tank has a drainplug on the bottom, but if it does, use it to empty the gasoline. You'll be able to tell if it's good or not by how clear it is.
Best of luck to you. Depending on how long it has sat, you might want to buy new sparkplugs and put an ounce or two of Automatic Transmission Fluid (ATF) in before cranking it over for the first time.
Old Aug 4, 2003 | 12:28 PM
Anex 570's Avatar
It Runs!
Ok thanks for the tips everyone. Where should I put that atf though, in the engine or tranny. Sorry if it sounds stupid but I just dont know all that much about rotory yet.
Old Aug 4, 2003 | 12:33 PM
wwilliam54's Avatar
it WILL run
down the carb
Old Aug 4, 2003 | 01:23 PM
pratch's Avatar
Mazspeed.com
Put a capful or two down the carb, turn the engine pulley 120 degrees, put another capful, turn the pulley another 120, put the last capful.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
