Sponsored by: CARiD
engine misses 4000 rpm
Old Aug 2, 2003 | 08:22 AM
cswanson's Avatar
I just got an 86 GXL that runs great until around
4000 rpm, and then the engine misses quite badly.
I realize that this is a very vague question, but thought I'd give it a shot. Plugs, fuel filter,.....??
Old Aug 2, 2003 | 09:27 AM
diabolical1's Avatar
it could be fuel filter or a bad ignition component. it could be bad timing. if you just got it ... give it a full tune-up (including wires), then if the problem persists, post again and let us know.
Old Aug 11, 2003 | 10:45 AM
cswanson's Avatar
4000 rpm lag
I've read numerous articles about the ground problem in the "boost sensor" being related to this problem.
Anybody here try this fix?
It seems like an easy task and one that could do no harm.
Old Aug 15, 2003 | 12:58 PM
Keisuke T.'s Avatar
Sounds like u r experiencing the common 3800 rpm hesitation. Do a search. Good luck.
Old Feb 26, 2006 | 05:34 PM
KamakazieX's Avatar
if its a 6 port see if they are frozen
would have the similar effect of a really retarded ignition
Kyo
Apr 13, 2019 09:24 AM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
Microtech
Aug 23, 2015 11:04 AM
