bearing?
Old Aug 1, 2003 | 03:40 PM
1SxyRXy's Avatar
my fc broke
bearing?
well ive had this noise in my car everytime the rear suspension flexes it makes this REALLY anoying noise thats is really loud. my dad thinks its the bearings but the thing that makes me think its not is that if i push down the back of the car it still makes the noise. what do u guys think. i also think it might be the little cop type thing that the top of the spring rests in because mine is all crusty
Old Aug 1, 2003 | 03:43 PM
Aaron Cake's Avatar
Engine, Not Motor
Well, what does the noise sound like?
Old Aug 1, 2003 | 03:45 PM
vectorminds's Avatar
Where's My Fuel???
i had a clunk in the rear, was the camber links going bad... id take a look at those
Old Aug 1, 2003 | 03:51 PM
1SxyRXy's Avatar
my fc broke
the noise is almost like something is rubbing togethre and its pretty loud from the outside it mainley sounds like its coming from around the disc or the whole shock tower
Old Aug 1, 2003 | 03:59 PM
Aaron Cake's Avatar
Engine, Not Motor
Jack the car up, take the wheel off and rotate. Put your ear close and listen to the source of the noise...
Old Aug 1, 2003 | 04:10 PM
1SxyRXy's Avatar
my fc broke
ive done that before but still couldnt find **** it sounds like the noise is come from everywhere. its driving me insane
Old Aug 1, 2003 | 04:44 PM
1SxyRXy's Avatar
my fc broke
ok i just went under my car and did all the stuff to try and figure out what it is and i think its the lower controler link. im gonna orders those maybe but they are 70 bucks
Old Aug 1, 2003 | 05:04 PM
SureShot's Avatar
Seduced by the DARK SIDE
Time for suspension bushings (every 120,000 miles or so)
The classic clunk - clunk is usually the rear trailing arm bushings, but could also be sway bar bushings or struts.
Old Aug 1, 2003 | 05:07 PM
1SxyRXy's Avatar
my fc broke
i was thinking of ordinger the whole bushing kid from that victoria british catalog.
Old Aug 1, 2003 | 05:08 PM
SureShot's Avatar
The RX-7 language:
Thunk (when starting out) - Front diff mount.
Tink (when starting out) - u-joints
Clunk or groan (with suspension movement) - old grommets.
Zoom zoom (short cycle) - vac leak
Zoom zoom (long cycle) - TPS or BAC or grounds
Crunch - high rev shift to 2nd
Beeeeeeee - over rev or low coolant or low oil.
RrRrRrRrR - starter gear sound (normal)
rrrrrrrrrrrr - starter gear sound (flooded)
RrRrRrrrRrrrR - starter gear sound (bad apex seal)
ls1swap
Jun 3, 2024 03:25 PM
Vartok
16
Oct 8, 2015 04:49 PM
