Won't stay running below 3k rpms
Old Aug 1, 2003 | 12:44 PM
Wanked_FC's Avatar
Ihre Papieren, Bitte?
Ok here's the deal. I swapped out my bad alternator last night. I took off the TMIC so I could have easier access to the alternator wires and what not. Prior to this I could jump start the car and it would run fine and idle at its usual spot. Now after I swapped in my new alt and put my IC back on it won't run below 3000rpms. If I mess w/ the throttle a lot and keep the revs high it runs, but rough, and makes lotsa back fires etc. Its behaving as if I have a huge vaccum leak, but I ripped off the IC again after it did that and checked for disconnected hoses, and put the IC back on and tightened up the clamps real well and it still wouldn't run. AFM, TPS, CAS, air and water temp sensors are connected. Any ideas? I'm at a loss, and I dunno why the hell its doing this. It would run perfectly b4 and now it runs for **** if it all.
Old Aug 1, 2003 | 12:54 PM
J-Rat's Avatar
Alcohol Fueled!
Somehow or another, youve gotten yourself a leak.
gergrx7's Avatar
Boosting Again
try reseting the tps
Old Aug 1, 2003 | 12:55 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
How do you reset the TPS?
What does it reset to? The stock setting?
Old Aug 1, 2003 | 01:07 PM
Wanked_FC's Avatar
<-----dumbass.... How do I set the tps, theres no adjustment screw on it that I can find. Its an S4 turboII.
Old Aug 1, 2003 | 02:01 PM
Wanked_FC's Avatar
<----- No longer a dumbass, tps is set correctly now. Waiting for battery to charge.
Old Aug 1, 2003 | 02:37 PM
Wanked_FC's Avatar
arrrggg, still doesn't run
Old Aug 1, 2003 | 03:01 PM
Aaron Cake's Avatar
Engine, Not Motor
It's a vacuum leak. Perhaps you crack an intercooler hose?
Old Aug 4, 2003 | 09:19 PM
Wanked_FC's Avatar
Its Alive! The damn brake booster came off behind the UIM. She runs great now, volts are good, and setting the tps smoothed out my idle and revs.
Old Aug 4, 2003 | 09:30 PM
J-Rat's Avatar
Alcohol Fueled!
Amazing what fixing a vac leak can do for the motor, isnt it?
Good fix!
Jarrett
Old Aug 4, 2003 | 10:35 PM
Rxmfn7's Avatar
Do a barrel roll!
Could someone show me where the brake booster line on the UIM is? I thought the only like that ran over to that was one from the charcoal canisted over to a metal line across the firewall? Then a small, large diameter hose a few inches long at the booster itself...
Old Aug 8, 2003 | 11:56 AM
eyeoutthere's Avatar
I was wondering the same thing. Except my brake booster doesn’t go to the charcoal canister, it goes to that “air pump stuff” on the LIM.
Old Aug 8, 2003 | 12:54 PM
Rxmfn7's Avatar
Do a barrel roll!
I think he is talking about the line that goes to the LIM, which I understand. I dont know if he just mis-typed, or there is a line that I cannot think of right now. If you follow the line from the brake booster, it goes along the firewall, then turns down and goes to a banjo fitting on the side of the LIM. At least on S4 N/As anyway..
Queppa
Nov 18, 2024 03:47 AM
Kyo
Apr 13, 2019 09:24 AM
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
