Power FC base fuel map apples to apples?
Old Aug 1, 2003 | 09:01 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
assuming a zeroed out fuel inj page and similar air and water corrections... if i compared 2 maps, with dissimilar fuel injector sizing, would i need to do a math correction in order to arrive at an apples to apples comparison of how much fuel was actually being injected?
thanks,
howard coleman
Old Aug 1, 2003 | 09:53 AM
weaklink's Avatar
Resident Retard
an interesting question. I have thought about this as well, as in, can I use a map from someone who runs 1600cc secs, when I have 1300s, but when everything else is the same. I would assume that the math correction you are referring to is on the injector sizing page (as you probably know). I think of it this way: If you had a stock car with a PFC, and all you did was swap injectors, then all the manual says you have to do is plug in the correction values. There are no changes to make to the base fuel or injector maps. So, in THEORY if you had two different cars which were similar except for injector sizes then you should have apples to apples for fuel as well, as long as the correct correction factor was applied for each. In REALITY we know that you can have 2 cars with identical mods run identical maps with different results.
Old Aug 1, 2003 | 09:49 PM
cewrx7r1's Avatar
Eye In The Sky
When I replaced my 850 with 1200s, my engine did not run 41% richer. I also think the injector correction logic
takes car of it.
1200/850= 1.41 or 41% larger. You should still wide band test after.
Old Aug 2, 2003 | 08:37 AM
thanks for your reponses.. they do answer the question.
howard coleman
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
Captain_Panic
Alternative Fuels
Sep 16, 2015 02:06 PM
