my mazda wont figgen start!!!!!!!!
Old Jul 31, 2003 | 07:41 PM
assman20a's Avatar
ok i have a 88 gxl
yesterday i went out and took the tip somebody gave me and took out the fuel pump and removed the check valve(to stop the floding) put it back together and started it up drove about 5 miles then parked it.
today i went outside and proceded to crank the thing over and over and over till the battery died
i have checked all i can think to check
i am lost in the woods now and dont know what to do
any suggestions would help
Thanx
Old Jul 31, 2003 | 07:49 PM
what? I've never heard this before. who gave you that tip?
I bet its still flooded. take a locking pliers and clamp off the fuel line (don't remember which one) and see if it starts. otherwise, there are a million other ways to start a flooded try some, and see if it starts.
Old Jul 31, 2003 | 07:50 PM
rxse7en's Avatar
Nothing to see here.
http://www.rotaryresurrection.com/flooding.html
Old Jul 31, 2003 | 08:06 PM
assman20a's Avatar
thanx i will try that
Old Jul 31, 2003 | 08:14 PM
gergrx7's Avatar
Boosting Again
ok what u need to do to unflood it is take out the egi fuse the farthest one from the drivers fender the crank it with it floored for abotu 10 seconds the put it back in and then crank it normaly. if that doesnt work do the same thing but on starting it the second time when the fuse is back in floor it it should start
Old Jul 31, 2003 | 08:37 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
You might have leaky injectors. Also driving short distances or for a short time can cause flooding as well if the car is not fully warmed up.
Old Aug 1, 2003 | 12:32 AM
theone81's Avatar
thank god i hava a s5
Old Aug 1, 2003 | 09:03 AM
WTF
i hate that egi fuse tip, it has never worked for me(no offense)
what i do is look under the dash just to the right of the steering column and there will be a relay, it looks like a little black plastic 1" x 1" x 1" box with a plug that plugs into it. that is your fuel pump relay unplug the plug and crank the car. it should start up and run on the gas that is flooding the engine....while it is running and burning of the gas in the motor plug the box back up and the fuel pump will start pumping fuel and the car will stay running. might take you a couple tries to get your timing right but it works everytime for me and you dont even have to get out of the car and pop the hood everytime!
Old Aug 1, 2003 | 09:02 PM
assman20a's Avatar
does anybody know the spark plug wire locations?
i might have scrued it up
Th0m4s
Feb 26, 2019 02:04 AM
The1Sun
Mar 18, 2018 11:08 PM
7aull
1st Gen General Discussion
Aug 14, 2015 10:44 PM
