correct offset for enkei rpm2's? what tire size...? fender flares?
Old Jul 31, 2003 | 07:38 PM
poor college student's Avatar
Red Mist
i'm looking to get a set of rpm2's 17x8 for the fronts, 17x9 for the rears, wondering what offset i should be looking at...?
Also, anyone know about rolling out the fenders or anything to accomodate a wider tire than a 225 in the front for an s5 gxl?
One more thing about the offset. Would it be bad to get something that would put a little more space between my wheel and the car? I had 225's on my stock rims and when one of the rears blew, i found out it was rubbing against the heatshield and the metal bar thing (180 degrees away from the heatshield in the rotational pattern of the tire... sorry, don't know how to describe it)... i was thinking maybe if i got something that gave me a few mm more space, i could prevent that from happening again (and i already bent my heatshield back closer to the exhaust.
if it makes a difference, i'm going to be running these w/ kyb agx and eibach pro's... not sure what size tire i should go with... suggestions?
Old Jul 31, 2003 | 08:21 PM
Red Mist
this forum isn't sponsored by rishie anymore...?
Old Jul 31, 2003 | 09:03 PM
Cheers!'s Avatar
Former Rx7 *****
+35 mm on the front 17x8
+40 mm on the back 17x9
+40 on the rear since that the only size that enkei makes that will fit right in the back. Ideally +35 all the way around is best.
235/40/17 is max tire fitiment, the problem is that it doesn't rub the fender, but the springs. You have to becareful about that.
Old Aug 1, 2003 | 03:58 AM
Red Mist
d'oh! it rubs the springs? i always thought it rubbed the fender (i've seen people who's tires have scars from the fender.... and i'm assuming 235/40 is max on the fronts... how wide could i get away w/ for the rears? i've seen 255's on an 8.5, so i'm thinking maybe 265 or 275....? not that i need that wide of a tire but....... it looks tight it's for the ricer in me, lol
Old Aug 1, 2003 | 04:52 AM
ARD T2's Avatar
Yup Cheers Got it. The forum isn't sponsored by me but doesn't mean that I won't be here to help just as I have always been. We just can't justify the expense at this time.
If you need advice you can always email me autornd@hotmail.com since I don't have PM's.
Later, Rishie
Old Aug 1, 2003 | 09:07 AM
Cheers!'s Avatar
Former Rx7 *****
you can maybe get away with 235/40/17, but you would have to have zero camber. You could maybe run a spacer, like 3 to 5 mm. I think if u run a 5 mm spacer the centre caps will clear the dustcap of the front wheel bearings.
But you may then hit the outside of the fender liner, hence you will need to roll it.
maybe 2.5 inch OD coilovers would be better... i'm not sure.
Old Aug 1, 2003 | 10:09 AM
Red Mist
well, i don't need wider than 235's in the front, so it's all good.... what 'bout the rears, cheers?
btw, thanks a lot
Old Aug 1, 2003 | 10:16 AM
Cheers!'s Avatar
Former Rx7 *****
i think the rears can take up to a 275 tire... i'm unsure about this... so if buy it and try it and it doesn't work... don't blame me...
https://www.rx7club.com/forum/showth...&highlight=275
275s will stick out a lot... i'm not sure what offset max has on his car.
Old Aug 1, 2003 | 10:42 AM
Red Mist
damn that's wide!!! maybe i'll go w/ 265's....
Old Aug 1, 2003 | 12:35 PM
Cheers!'s Avatar
Former Rx7 *****
there isn't much selection for 265 tires... i find it is either 255 or 275.
Old Aug 1, 2003 | 01:19 PM
ARD T2's Avatar
Beware of your gearing. I would suggest sticking to a 255 but I guess that all depends on how much power you're putting down.
Rishie
Old Aug 1, 2003 | 01:57 PM
Cheers!'s Avatar
Former Rx7 *****
well ideally 275/35/17 is good... only 1.2 % off from the size of 205/55/16
but 275/40/17 is only 3.1% off
not too bad... but i have to agree.. i think 255 is plenty wide... considering stock is 205... u are already getting an extra 50 mm of thread..
rishie, do 2.5 in OD coilover springs help with the tire rubbing the spring? or is it hte same as stock, it will rub regardless. I'm not sure.
Old Aug 1, 2003 | 09:25 PM
bkapold@aol.com's Avatar
275's will fit on the rear....I have them on my car with 17 x 9.5" Enkei RPF1's w/ 2 deg NEG camber. 10's will fit too but Enkei had a hard time coming up with another wheel for me and I had to settle for 9.5's ohhh well.
235's will fit on the front with a 17 x 9" wheel w/ 1 deg NEG camber...
I do know of someone with 245's on the front and 285's on back with no flairs...
Old Aug 2, 2003 | 04:31 AM
Red Mist
yeah, i don't really think i need a 275, i'm not putting down that much power (i'm n/a ) but it'd be nice to look at.... so it's between 275's and 255's.... won't 255's look kind of small on 9 inch wide wheels?
Old Aug 2, 2003 | 08:26 AM
Poor college guy :
funny you ask that but a 245-255 stretch'd on a 9-10 wheel is really the **** for the track....It makes the car stiffer with less role....When I got my 9.5's I had a 255 on there and it looked wide as hell on there, but I thought the whole reason for getting a wide wheel is to hook up and so I opt'd for the 275'R...
If you look at real race cars alot of them run narrow'r tires on wide wheels...but then again a 315 on a 12-13" wheel isn't exactly narrow
BTW: I don't think of you as being a poor college student standing next to that hottie
Brad
Old Aug 2, 2003 | 11:37 AM
Red Mist
hahaha
well, i won't be using these for track... i'll be keeping my stock turboII wheels and putting maybe some azenis sports 225/50/16's on them.
as for the avatar chick, she's a model i ran into at both mr. olympia and at sema last year... what can i say, she was a hottie!! nicest girl you'll ever meet at one of those shows too
Old Aug 2, 2003 | 01:10 PM
Cheers!'s Avatar
Former Rx7 *****
did u get her number?
Old Aug 4, 2003 | 12:17 PM
Red Mist
i wish... maybe if i see her there again this year.....
last year i was too busy gawking and mumbling when i was talking to her, lol
Old Aug 4, 2003 | 01:19 PM
Red Mist
question.... so if i go with 225's in the front and 255's in the rear... will the tires be too small looking for an 8" and 9" rim on my fc?
Old Aug 4, 2003 | 01:29 PM
Cheers!'s Avatar
Former Rx7 *****
in my opinion if i can't run anything that is 235 or more on any wheel i've wasted 1200+ dollars on wheels and tires. I can accomplish 225/50/16 on my stock TII meshies...
if i only got 225/45/17 on the fronts on a rim that cost 200+ dollars i would be pissed.
Old Aug 4, 2003 | 08:00 PM
You can fit 235's on front, just might have to tweek things depending on offset, camber, toe, etc.... I know of someone who has 245's
Old Aug 5, 2003 | 02:30 AM
Red Mist
well what would it take to put wider tires in the front without rubbing...? that's the thing, i don't want my fender cutting up my tires if i corner hard... that's the thing i'm worried about...
as for the rims, i'm getting hooked up with them... new for <175/wheel
Old Aug 5, 2003 | 07:58 AM
Cheers!'s Avatar
Former Rx7 *****
just get the +35 offset front 17x8
if it rubs the spring then add a spacer. Start at 2 mm and work your way up to 5 mm.
if u use a spacer u will need to roll the outer fender lip so i doesn't cut the tire. I think rolling fenders cost around 80 Canadian dollars per fender.
Old Aug 5, 2003 | 09:36 AM
Red Mist
what kind of place does fender rolling? any pics of what it looks like?
Old Aug 5, 2003 | 09:43 AM
Cheers!'s Avatar
Former Rx7 *****
body shops offer it. same with some tire/wheel places that push out a lot of aftermarket alloy wheels.
Also what are u doing for centre caps? the ones that come with the wheels won't fit over the dust cap/axle lock nut on the FCs.
