just a simple quick question
Old Jul 31, 2003 | 01:26 AM
chiefnobum's Avatar
Question just a simple quick question
for an 86 stock GX what size and amp fuel injectors can I use? I am not going to be doing any upgrading for a while except maybe a cold air intake and it does have custom exhause but still all the cats. I would just like to know what would work and if there are any cheap ones around?
Old Jul 31, 2003 | 01:29 AM
$150FC's Avatar
Currently Winning
for an n/a, unless you are HEAVILY modded there is no reason to upgrade your injectors. You would only be decreasing power.
Old Jul 31, 2003 | 01:30 AM
$150FC's Avatar
Currently Winning
Oh, yeah. An S-AFC can let you lean out the mix a bit, but you simply don't *need* bigger fuel injectors.
Old Jul 31, 2003 | 01:32 AM
chiefnobum's Avatar
I meant that mine are bad and I need new ones so which sizes can I look to get?
Old Jul 31, 2003 | 01:36 AM
$150FC's Avatar
Currently Winning
Oh. 440s.
Old Jul 31, 2003 | 01:40 AM
chiefnobum's Avatar
if I did happen to find some other sizes for really cheap are they ok?
Old Jul 31, 2003 | 01:47 AM
NZConvertible's Avatar
I'm a boost creep...
Stock NA injectors are 460cc/min. If you go any bigger than that you'll just run very rich and lose power.
Why do you need four new injectors? It's unusual to find an injector that can't be reconditioned to near-new condition. I've never heard of anyone needing to replace all four...
Old Jul 31, 2003 | 01:52 AM
chiefnobum's Avatar
well I found some injectors for 40 dollars a piece and I haven't found a good place to rebuild mine anytime recently...Mazda dealership quoted me 700 to do it all for me...I said no If you know of any good places though for rebuilds that would be really cool
Old Jul 31, 2003 | 01:55 AM
Check out RC Engineering's website...they are a very well known company.
Old Jul 31, 2003 | 05:30 AM
Send them to a company like RC Engineering, or look in the yellow pages for someone local. Any EFI specialist will do it (or send them out), or you could try diesel service companies. Some will do petrol injectors as well, and are often cheaper than EFI places.
Old Jul 31, 2003 | 02:07 PM
chiefnobum's Avatar
I phoned a bunch of places and they say they will only do a purge which is running straight cleaner through the whole fuel system...would that work to clean them properly. They tell me it should but that sounds too easy.
Old Jul 31, 2003 | 02:42 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
Just send them to RC or some company like that. My friend had his cleaned for around 60 dollars at a place like that.
Old Jul 31, 2003 | 02:50 PM
Jodoolin's Avatar
Take a look see at this injector cleaning link. Several posts in past have good words.
http://www.cruzinperformance.com/fuelinj.html
Old Jul 31, 2003 | 06:21 PM
88mazdarx7turbo's Avatar
numba 1 stunna
just stay with the normal 460 injectors no need for bigger
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
ZacMan
Sep 19, 2015 09:20 PM
Nosferatu
Sep 5, 2015 02:13 PM
