Broken exterior Door Handle
Old Jul 30, 2003 | 03:35 PM
MechE00's Avatar
Hey guys, thought I'd see if anyone had any experience fixing/replacing the door handle on their 7... I have an 86 and the driver's side exterior door handle has broken. The broken part is the tab inside the door that pushes down on the rod that unlatches the door when you lift the handle. I can open the door from the inside, but I'd like to get things fixed.
It looks like I'll have to find a replacement handle (junk yard?) and somehow get the old one out and the new one in, but it's a really tight space to work in..
Suggestions? Tales of experience?
Many thanks..
Old Jul 30, 2003 | 03:37 PM
Aaron Cake's Avatar
Engine, Not Motor
Really easy to do. Get a new door handle, then remove the door panel (a few screws, carefully pry it up). Use a small 10MM socket wrench to remove the two bolts that hold on the handle after you unclip all the rods. Pushes right out.
Old Jul 30, 2003 | 06:43 PM
86J's Avatar
86J
You should just call the mazda dealer and buy a new one b/c once you get a used one and paint it, it will probably be the same price as a new one from the the dealer. and the dealer gives you a 1 year warranty. i think i paid $85CDN from the dealer.
I already broke my driver side twice and the passenger once, actually my friend broke the passenger side one.
i found it easy to get out if you open the handle when your taking it out, but since the handle is broke push down the piece that broke off the handle and then pull it out.
Old Jul 30, 2003 | 09:15 PM
jgrts20's Avatar
Who are you?
i had to replace my passenger side one, it was easy and the junkyard i got it from has a gold 7 same color as mine!! Aaron tells u how to do it!! i figure i give u somemore support!!
Old Jul 31, 2003 | 12:17 PM
MechE00's Avatar
Many thanks guys! I'll try to get to it this weekend or next..
Old Jul 31, 2003 | 12:30 PM
sectachrome's Avatar
pistons=teh suck
i think rotary resurections website has a few handles you can buy.
