Tap & Die question...
Old Jul 30, 2003 | 04:50 AM
adamlewis's Avatar
Back from teh deadly!
If I want to tap a hole to accept a 14mmX1.5 sensor, what do I need to call around and ask for? I understand I need a 14mm drill bit too?
Im so confused...
Old Jul 30, 2003 | 05:08 AM
1SxyRXy's Avatar
my fc broke
u will need a tap. its actually not that hard. just drill the hole the size u need it then thread it
Old Jul 30, 2003 | 07:40 AM
Hot_Dog's Avatar
Re: Tap & Die question...
Im so confused...
If you're planning on cutting 14 mm internal threads, than you don't want to use a 14 mm drill bit because you won't have metal left to cut into. As a rule of thumb, when cutting internal threads, the hole size should be the major thread diameter minus one over the pitch. Simply put, 14 - 1/1.5 = 13.333 mm (or 0.525 inch) should be the approximate size of the drill bit. There are machinist's charts available that give the required hole size for a specific tap.
Hot_Dog
90 RX7 GXL
02 Acura RSX-S
Old Jul 30, 2003 | 10:05 AM
Derek 357i's Avatar
Here is the tap chart I use
http://www.carbidedepot.com/formulas-tap-metric.htm
Old Jul 30, 2003 | 11:57 AM
HAILERS's Avatar
HAILERS
Thanks for the drill chart. Bookmarked.
Old Jul 30, 2003 | 12:07 PM
CarmonColvin's Avatar
Check out www.mcmastercarr.com
Browse to page 2220 in their catalog.
They suggest a drill size of 12.5 for a 14x1.5mm tap.
I bought the taps required for a rebuild from them. Excellent customer service and fast delivery.
Old Jul 30, 2003 | 02:11 PM
Kyrasis6's Avatar
MazdaTruckin.com Founder
Solomiata
Here is the one on Solomiata, personally I don't like it there are better ones out there, I'm posting it just for another reference.
http://members.aol.com/solomiata/tapdrillchart.jpg
Old Jul 30, 2003 | 02:57 PM
adamlewis's Avatar
Ok...What size drill bit would I need for a 3/8 NPT tap?
Old Jul 30, 2003 | 03:00 PM
banzaitoyota's Avatar
What Subscription?
37/64
Old Jul 30, 2003 | 03:11 PM
adamlewis's Avatar
Originally posted by banzaitoyota
37/64
And exactly how did you figure that out?
Thanks BTW
Old Jul 30, 2003 | 03:19 PM
What Subscription?
I have a decimal equivlant and Tap dRill size Chart in my Cubicle. When that fails I reference Machinery's Handbook.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Prediict
32
Nov 18, 2015 08:41 AM
LongDuck
Oct 7, 2015 08:12 PM
Rotafuzz
Sep 30, 2015 09:55 AM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
