Help!!! 2nd Gen. Dies after it turns over.
Old Jul 29, 2003 | 09:02 PM
myron96's Avatar
Here is one for you guys, hopefully someone can help me out!!! I just had a new engine put into my 2nd gen vert by KD rotary... It ran great for the first week or so, and now for some reason, when i turn the key over, the car starts, but as soon as i release the key from the start position, the engine dies!!!! Any ideas?!!!!! Thanks!!! John
Old Jul 29, 2003 | 09:47 PM
turbo II addict's Avatar
check to see if the bac valvle is hooked up right a lose hose could do that mabey
Old Jul 30, 2003 | 01:16 AM
yearrgh's Avatar
Must...scrub...parts...
Does it rev to 3k and immediatly die? If so the AFM came unplugged.
Old Jul 30, 2003 | 02:18 AM
boosted1205's Avatar
You have a **HUGE** vacuum leak somewhere. Don't let teh capital letters scare you.
Check the TID going to the turbo, brake booster and AFM connector. Check to see if all the clamps after the AFM are on tight. If it's a small leak, it'll just idle wierd.
Old Jul 30, 2003 | 11:55 AM
Spawn VII's Avatar
either a huge vacuum leak or your ignition switch is shot
Old Jul 30, 2003 | 12:23 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
I second the loose AFM. Happend to me over the weekend.
Old Jul 30, 2003 | 02:54 PM
mac_dad6's Avatar
check the afm connector, mine did the same thing
Old Jul 30, 2003 | 03:51 PM
Aaron Cake's Avatar
Engine, Not Motor
AFM. The AFM contains a switch that disconnects the fuel pump if the car is not running (no airflow). If the connector has come loose or this switch is bad, the car will only run when the key in the "start" position where this safety is bypassed.
You can prove this by jumpering the yellow test connector found near the passenger shock tower. With that jumpered, the fuel pump should run anytime the key is on the "ON" position. DO NOT drive like this, fix the problem. In the event of an accident, the fuel pump will still be running, possibly starting a fire.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
