question about s5 tps
Old Jul 29, 2003 | 06:48 PM
Fingers's Avatar
I'm thinking... when you set the tps using the two light method, which plunger does it look at?
I remember when doing the ohm test, it read 1000-3000ohm, as opposed to the factory spec 1000-4000... maybe the short range tps is out of range. Perhaps this could be the cause of my trouble?
The SAFC looks at the wide-range tps, and that stays pretty much constant.
Anyone wanna shed some light on this?
-Ross
Old Jul 29, 2003 | 07:00 PM
SureShot's Avatar
Seduced by the DARK SIDE
As you might guess, it's the ECU's interpretation from the short range TPS.
Two things fixed mine.
Spray contact cleaner between the barrel & sleeve of the TPS plunger, work it in, blow it out.
Beefed up ground at the firewall.
Old Jul 29, 2003 | 07:05 PM
Fingers's Avatar
son of a bitch, its what i thought :S Time for a new tps.
_Tones_
May 25, 2021 05:37 AM
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
Nosferatu
Sep 5, 2015 02:13 PM
