ever seen this carb issue?
Old Jul 28, 2003 | 02:01 PM
FB II's Avatar
ok; i found out what the hell is happening. my car keeps cranking over and then dieing out. so i looked in the carb right after it died and i noticed that there was SOOO much fuel! it is severely kicking out fuel! WHY???? we set the floats to 9/16th like everyone says to on here. what could be wrong?
Old Jul 28, 2003 | 02:14 PM
enigma32's Avatar
Turn the ignition to the "run" position and take a look....
If it's dumping fuel while in "run" when the engine isn't turning then you likely have a stuck float.....
Old Jul 28, 2003 | 02:16 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
floats set too high. fuel level should be in the middle of the sight glass. if not, adjust floats so it does.
could also be trash in the needle and seat.
or too high fuel pressure.
Old Jul 28, 2003 | 02:58 PM
FB II's Avatar
i'm using the stock fuel pump. how do i adjust the float level? is it really supposed to be set at 9/16ths? cause that's where it's at damnit
rgordon1979
40
Mar 15, 2022 12:04 PM
Clacor
Sep 11, 2015 08:36 PM
<<Ayrton>>
Interior / Exterior / Audio
Sep 5, 2015 09:38 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
