Haltech I need a map to start me off
Old Sep 14, 2001 | 07:38 PM
Rx_treme's Avatar
i am going to be using the stock turbo on stock injectors with 8-9 psi. just need one to get the car started after its installed. oh yeah its a e6k and also do i need the BAC if i dont have AC?? thanks
Jason
Old Sep 14, 2001 | 08:11 PM
HWO's Avatar
HWO
inteligent extratarestril
what model and engine? S4, S5 or S6? 13BT or 13BREW i presume
Old Sep 15, 2001 | 02:06 PM
Rx_treme's Avatar
oh yeah its a series 4 engine uh 13bt (88), with the normal mods, full exhuast, intake, TB mod, FMIC, stock turbo and injectors.
Jason
Old Sep 16, 2001 | 12:36 AM
HWO's Avatar
HWO
2 or 3 bar map sensor?
Old Sep 16, 2001 | 01:39 AM
Rx_treme's Avatar
haha damn i keep forgeting to put important **** like that in.. its a 3 bar map sensor, hmm anything else that could change it?! Also can i take off my BAC valve even if i decide to put on a/c later on??
Thanks
Old Sep 16, 2001 | 04:40 PM
Silver7's Avatar
I would recommend not using your bac valve if you are not going to use your AC. The car seems to idle much better w/o the bac valve. You can take off your bac valve, but if you decide to use your AC, I would put it back on. If not, your car will stall or idle very low when your AC is on. The AC will knock your idle down about 200 rpms or so.
Old Sep 17, 2001 | 12:38 AM
Rx_treme's Avatar
Yeah i have decided to just take off the BAC.. so does anyone have a pretty much stock map??? thank you
JAson
Old Sep 17, 2001 | 12:43 AM
Rx_treme's Avatar
I also forgot to ask when i take off my BAC i dont have any other coolant things, like the TB no BAC etc. so can i just plug the back side of the coolant neck and the top of the back rotor housing. or should i just run a hose from the coolant neck to the back rotor housing under neath the TB and intake.. thanks
Jason
Old Sep 17, 2001 | 01:04 AM
HWO's Avatar
HWO
yeah i have a map which is suitable for ya if i could find ya e-mail addy i'd send it to ya but i cant seem to find it, post it and i'll send ya the map
Old Sep 17, 2001 | 06:40 PM
Rx_treme's Avatar
its snyper10x@msn.com so that map is good to just get it running and driving right?? not much else....
thank you
Jason
Old Sep 21, 2001 | 04:08 AM
HWO's Avatar
HWO
DONT GET ON BOOST WITH THAT MAP DUDE, I JUST REMEMBERED I HAVE 800CC SECONDARIES AND THAT IS WHAT THAT MAP IS MENT FOR, YOU'LL BE SWEET OFF BOOST BUT DONT GET ON BOOST YOU'LL LEAN OUT TOO MUCH AND BLOW SOMETHING
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
