LDash board lights on??
Old Jul 22, 2003 | 04:51 PM
mmonaco's Avatar
Part out my Car
I just started to have a problem with my DD 1st gen 12a. I noticed the lights on the dash were all on all the time. And the battery gauges isnt working and the battery is dieing slowly it barely could roll up the window today? Anyone know what is going on? Thanks
Marc
Old Jul 22, 2003 | 07:00 PM
Directfreak's Avatar
I am a Jeeper Now.
It's the alternator. Make sure it's working fine, and that the plug on the back is properly making contact.
Old Jul 22, 2003 | 07:49 PM
BadAssRX-7's Avatar
The AUTO DOCTOR
nice ***** D.F.
Old Jul 22, 2003 | 09:11 PM
enigma32's Avatar
The lights on the dash are on all the time?
i.e., the backlight for the instrument cluster?
If *that's* on all the time you'd best be checking your combo switch for the headlights, I imagine
Old Jul 22, 2003 | 10:59 PM
mmonaco's Avatar
Part out my Car
No not the lights on the cluster its the parking break light, low gas...ect! so you think its the alt ill check it out in the morning! thanks
Marc
Old Jul 22, 2003 | 11:03 PM
enigma32's Avatar
hmm... that's quite interesting.
And you don't have the parking break on and no gas in the tank? =)
Just for the heck of it, check your engine fuse too....
I had a blown engine fuse and it caused weird stuff with my notification light thingies...
But beyond that, I'm outta ideas =)
Good luck!
Old Jul 23, 2003 | 12:30 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
Here's what you do. Check the belt for the alternator. Is it slipping badly or did it manage to break off? That alternator isn't gonna spin itself. if everything looks normal with the belt and all, then check the connections like DirectFreak mentioned above. If those look good then start the car and touch a screwdriver to the flat round part right in the back of the alt. If it pulls like it's magnetic then it's possible that it is fucntioning normally. If it pulls really weak or doesn't seem magnetic at all then it is most likely shot. Good luck.
Old Jul 23, 2003 | 02:48 AM
djmickyg's Avatar
you gota love when your driving down the road then all of a sudden all the lights come on and you you think tyo yourself "BLOODY FANBELTS!"
like everyone else said, its a charging problem..
do the scredrver trick as said above or if u got a voltmeter, messure the voltage arross the battery when the cars revving at about 2000-3000 and if its isnt at 14v then there is a prblem..
The1Sun
Sep 15, 2015 04:45 PM
Blastfastrotary
Sep 11, 2015 12:26 AM
The1Sun
Sep 7, 2015 10:21 PM
