Overheating
Old Sep 13, 2001 | 09:03 AM
RX AGENT's Avatar
Overheating
What causes a Turbo ll engine to overheat? Can it be fixed? I'm looking at one selling for 1500 Canadian dollars, is it worth to fix? Turbo ll's usually go for about 6000 to 8000 here.
Old Sep 13, 2001 | 09:10 AM
The Ace's Avatar
Greek Power
Talking
Overheating is so generic, you could search for hours and still not be able to find the root of the problem...
Common things to check: oil pump and lines, radiator/water pump/thermostat/lines, fan/clutch/thermostat. If these are OK, then check the A/C fan, the oil cooler, or the engine itself for leaks. If you still havent found the problem, then you should take the engine apart...
JoesFC
Oct 5, 2015 08:10 AM
Devon Murray
Sep 25, 2015 09:41 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
erevos
Sep 15, 2015 09:19 AM
