Microtech Map Sencer?
Old Jul 6, 2003 | 06:21 PM
Map Sencer?
Hi all.
I am just intrested in the Map sencer set up on the LTX12.
What i would like to know is does it use the stock 2bar (unless its been uprated to a 3 bar) or does it use a complete diffrent set up?
Also how reliable would you say a Map sencer is? if i use my stock one and keep the Boost down is there any chance it will be worn ie. give a bad reading?
Having said all this i would like to point out my new engine will be running under 14psi and so would not realy need a 3bar, basicly i would be buying one for the sake of it.
Cheers
Chris
Old Jul 6, 2003 | 10:44 PM
No7Yet's Avatar
Microtech EMSes come with their own (new) 20 PSI MAP sensor. The stock one can be discarded. The 3 Bar MAP sensor is optional.
Brandon
BR7 Racing
Old Jul 9, 2003 | 07:33 PM
Fox4Life's Avatar
when did this come into effect? i was under the impression that all the Microtech's came with 2 bar map sensors.
Old Jul 9, 2003 | 09:26 PM
No7Yet's Avatar
Eh? It's always been this way. "2 Bar" was always just a convenient way of differentiating between the standard and 3 Bar MAP sensors. We've begun to cease using that term, however, since the standard MAP sensor is actually a 20 PSI unit.
Brandon
BR7 Racing
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
nismorx7
Power FC Forum
Oct 1, 2015 10:36 AM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
