Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
fuel starvation?
Old Jul 6, 2003 | 12:07 PM
kerniki's Avatar
Unhappy fuel starvation?
Hi
hopefully someone can point me in the right direction, i've got a 92 jap import 3rd gen, which has Apexi Induction, free flow back box, uprated fuel pump and regulator and an Apexi Power FC ECU.
I'm running .9 bar (13 psi) boost pressure and the car handles it fine in 1st and second gear, but 3rd gear and up I'm getting what feels like fuel starvation, intermitent at regular spacing when the second turbo spools up, it's fine when it first cuts in for about a further 1000 rpm then the problem starts and continues untill about 6500 and then it's fine untill the rev limiter, the Inj duty cycle monitor says they're only working at 89%, anyone got any ideas on what it could be?
Any help really apreciated, Nik
Old Jul 6, 2003 | 02:52 PM
fatboy7's Avatar
Got Boost?
Any injector duty cycles beyond 80-85 causes some injectors to go static, which could cause a bog.... do you have any way of measuring AFR?
Old Jul 6, 2003 | 03:08 PM
kerniki's Avatar
Excuse my stupidity fatboy, but what is AFR? is it Aif Fuel Ratio? if so I'm runing a power FC and comander so there should be a facility on there I would have thought.
Cheers, Nik
Old Jul 7, 2003 | 12:00 PM
Cosmo Donk's Avatar
Queer
Yah, AFR is air fuel ratio. If you have the PFC (Power FC) then there should be a reading for that. Can the PFC datalog? If so, do a datalog when you get the car to stumble and see what is happening.
You could just have too much boost for the fuel. Well, too much air for the fuel etc..
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
