Notes on engine pull
Old Jul 5, 2003 | 09:34 AM
pomanferrari's Avatar
I pulled the motor yesterday. The time it took to pull was less than 1 hour but the time to prep it for the engine pull took about 6 hours. We did it with the tranny attached.
These are notes of what I remembered as being problems:
1. take digital pictures of areas you're working on at each major stage;
2. de pressurize fuel line before starting job;
3. spray penetrating oil on the oil cooler connectors, use a dental pick to remove the clip;
4. it's easier to plug the drain on the p/s reservoir and remove the whole p/s pump. Four nuts must be removed before the p/s pump can be removed. If you've only 3 nuts, look for the 4th.
5. I don't know how people can remove the a/c and leave it with the car. I just removed the a/c line and out it came with the engine.
6. The wiring harness has to go through the firewall, remove the ABS heat shield but not the ABS. Spray WD-40 on the rubber grommet and a pry bar to pop the grommet off.
Old Jul 5, 2003 | 09:43 AM
911GT2's Avatar
The Power of 1.3
Good to know if I ever pull my engine. But hopefully that won't be for a looong time.
Old Jul 5, 2003 | 01:12 PM
kyle@insight's Avatar
Dont like it? I dont care
Good info
Old Jul 5, 2003 | 01:46 PM
sporff's Avatar
what's the deal with that wiring harness anyway? there's no plug on the engine side? that always seemed weird to me.
Old Jul 5, 2003 | 09:16 PM
paw140's Avatar
Why did you have problems with the AC? I just unbolted it and left it there...
Here's a really good thread:
https://www.rx7club.com/forum/showth...ghlight=engine
Th0m4s
Feb 26, 2019 02:04 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
maikelc
Aug 24, 2015 11:04 AM
