for automatic owner
Old Sep 11, 2001 | 06:59 AM
puma's Avatar
canadian monster
for automatic owner
hi guys
i am currently working on an automatic fd that has some boost problem.
my problem is that i don't know how the car should react since it is an automatic an i am used with my manual.
Do you know if the boost pattern should be the same on an automatic?
i only have 5 psi and doesn't seem to be any transition between the turbos. It always stays between 5 and 6 psi.
what is the best way to test an automatic
thanks a lot
puma
Old Sep 11, 2001 | 01:55 PM
unixpilot's Avatar
Check out my Mooseknuckle
Hi,
Boost test on an automatic should be done as follows:
Find a nice safe straight road
Put tranny in "S" with "Hold" engaged
Floor it
Should see a full 10 psi on the primary turbo around 2800 - 3000 RPM
4500 RPM transition, with a drop to 8 psi, immediately building back up to 10psi until redline (some hold 10psi, some bleed down to 8psi, but shouldnt go lower than 8).
When I slapped a boost gauge on mine for the first time, I was only getting 5psi on the secondary turbo. Ended up being a plugged main Cat.
Hope this helps.
Old Sep 11, 2001 | 02:01 PM
puma's Avatar
canadian monster
ok thanks a lot, i guess it is just the same thing as a manual.
do you know if a clogged cat can be problematic on both turbos or just the second?
Old Sep 11, 2001 | 03:43 PM
unixpilot's Avatar
Tough to say what the problem is.... plus Im not an expert on troubleshooting seq. turbos.. But most of the boost problems seem to be centered around the Turbo Control System, or Vacuum system.
Whats the history on the car? How many miles?
Mods? (Downpipe)
Vacuum hose tie wrapped?
If not, and its a 50k+ mile car I would say there's a good chance that the precat, or main cat could be plugged. In which case, that would kill your boost, especially on the 2nd turbo.
Old Sep 11, 2001 | 06:14 PM
puma's Avatar
canadian monster
in fact, the car is stock but they just changed the engine so it probably is a wrong plugged hose.
puma
RX7-RR
Jun 10, 2018 11:40 AM
