Eliminating Air Pump
Old Jul 3, 2003 | 10:31 AM
TOPLABELS's Avatar
I am sure some of you guys have eliminated de air pump from your rx-7. What are the advantages and disadvantages. Is it worth it as far as HP increase. When eliminating are there any particular things I need to do?? As usual many thanks to those of you who take the time to answer.
David Gerli
Old Jul 3, 2003 | 11:27 AM
enigma32's Avatar
https://www.rx7club.com/forum/showth...emove+air+pump
PS: I found those by searching for "remove air pump"
Old Jul 3, 2003 | 10:08 PM
Rx7carl's Avatar
Airflow is my life
No hp increase, just simplification of the car.
http://maz_tutorials.totalimmage.com/
Shameless plug.
Old Jul 4, 2003 | 12:00 AM
13B4port's Avatar
Will Work for Beer
that's not correcct. if you remove the air pump thats one less thing that the engine as to turn. also it lets te exhaust flow freer b/c it isn't dumping air into the exhaust to "dilute" the emissions. so there is a little gain.
Old Jul 4, 2003 | 07:24 AM
inittab's Avatar
I read your email
Re: Eliminating Air Pump
Originally posted by TOPLABELS
Is it worth it as far as HP increase?
NO!
Old Jul 4, 2003 | 07:32 AM
O 16581 72452 5's Avatar
The infamous number guy!
Mine came with the airpump removed and the backpressure pick up tube removed... yet they didn't block off the acv. There are some power gains to it, and i'm sure it could be shown on a dyno, are they substational? no. The airpump does take air from the intake, and it is a compressor so it does drag the engine down a little. Power gains would probably be 1-3hp at the wheels.
Old Jul 4, 2003 | 07:54 AM
inittab's Avatar
I read your email
Originally posted by O 16581 72452 5
...and it is a compressor so it does drag the engine down a little.
actually it's not a compressor, it's just a puff puff vane pump. If you really want a good HP gain don't run your A/C. Now, that's a compressor.
--Bob
Old Jul 4, 2003 | 08:13 AM
It sucks air in and blows it out... right? a compressor in my opinion. I've never seen one and really have no idea how they work though.
Old Jul 4, 2003 | 02:55 PM
pratch's Avatar
Mazspeed.com
Compressors by definition suck air in and blow it out, however, they suck in air at one pressure, and blow it out at a higher pressure. Hence the oh-so-clever-name of compressor
The air pump isn't a compressor - it's a pump since it merely transfers air from one location to another. much like a... pump
Damn, I'm in a smartass mood today - gotta love it though
Old Jul 4, 2003 | 09:34 PM
Northern 7's Avatar
If you're running a header w/o cats, the pump serves no purpose other than creating sonic boom backfires (which I can't stand). It's also added weight and another belt to turn - not a lot in HP gains but useless none the less - However, if you do remove it, I would add the dual alt pulley.
Old Jul 4, 2003 | 10:06 PM
pratch's Avatar
Mazspeed.com
Or per the tutorial in sig (and Carl's post) adding the 3L220 belt. Cheaper than a dual alt pulley and more effective in some ways.
Old Jul 4, 2003 | 10:12 PM
Northern 7's Avatar
Yeh - I used to have the 3L220 on my 12A but I couldn't get this belt to work on my SE due to the large A/C pulley being in the way (couldn't fit the small belt over the AC pulley). I haven't heard much negative on the dual pulley - Pratch, please share your findings - is there an issue with the dual pulley??
Old Jul 5, 2003 | 09:11 AM
pratch's Avatar
Mazspeed.com
Not an issue per se. It's basically that the motto that Carl and I have been focusing on with the tutorials is "cheap power". If it can be done for $5, we'll show you how. If you have access to a dual sheave alt pulley, then by all means, use it. However the amount spent is going to be more than the 3L220 belt.
We're not cheap, we just like focusing on spending as little as possible
rotor_veux
Sep 3, 2015 07:10 PM
