Compression Results, Bad news?
Old Jul 2, 2003 | 07:31 PM
dhahlen's Avatar
FD Under Construction =P
My compression test came out 90s on the front rotor and 80's on the rear. What should I expect to see there? Compression is obviously a bit low, I heard it should be anywhere from 80-140. The dood at the shop said he found a vacuum line that was broke, and a switch that was broke also... any clue what these could be? Anyone have any ideas... let me know.. (car is having idle problems, stalls sometimes when A/C is on) and it's not a MAP sensor problem. Any idea on the compression results either?
Old Jul 2, 2003 | 07:40 PM
Mr rx-7 tt's Avatar
rotary sensei
You need to know what EACH of the three readings on each rotor face is, three in the front, three in the back for a total of six.
Old Jul 2, 2003 | 07:42 PM
vosko's Avatar
Just Call Me Terminator!
does the car idle ?
if it does and has power the engine is fine
dhahlen's Avatar
Those were just peak readings... =/
Old Jul 2, 2003 | 07:48 PM
jspecracer7's Avatar
1JZ powered
if those were peak readings, then your fine...IF the peak readings are the same for all 3 sides of the rotor.
Old Jul 2, 2003 | 07:49 PM
dhahlen's Avatar
Yes the car does idle... but rough. Can vacuum switches cause all this crap? Apparantly one of them was busted....
Old Jul 2, 2003 | 11:00 PM
Mr rx-7 tt's Avatar
rotary sensei
Peak readings are the highest number out of one of the three pulses, it tells you nothing.
He needs to take it to someone who has a rotary compression tester and do a real test.
Old Jul 3, 2003 | 12:06 AM
kyle@insight's Avatar
Dont like it? I dont care
The busted vacuum lines can cause your car to idle funny, address that problem as it's an easy fix then get a real compression test done.
rgordon1979
40
Mar 15, 2022 12:04 PM
ZacMan
Sep 19, 2015 09:20 PM
BLK 93
11
Sep 9, 2015 10:56 AM
SCinfidel
Sep 8, 2015 05:36 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
