what is max safe boost on 3mm porcelain seals?
Old Sep 10, 2001 | 11:13 PM
artguy's Avatar
WTB** Very Low Miles 94-95
hi all
blew out my apex seals this past weekend...sob.
Im doing the engine rebuild and putting in 3mm porcelain seals. max boost on those seals according to mazda is 24 lbs.
What is the max safe boost that you all run on porcelain seals. I DO NOT want to blow them again...but I do want to up the boost if possible.
I have stock turbos...and they are being rebuilt again upon engine rebuild.
also...is there any better apex seals available that can boost over 24lbs?...not that I will...I just want the strongest out there.
thanks
jason
94 PEG
streetport
pettit intake
gforce ecu
manual boost controller
act clutch
n1 dual
hks downpipe
h&r springs
koni yellows
yokohama intermediates
hks turbo timer
etc...
Old Sep 11, 2001 | 12:38 AM
artguy's Avatar
maybe I should ask...what apex seals are you running and what boost are you currently at?
jason
if your car runs like *****...I dont want to know what ya got..haha...I got a car like that already....unless of course you know what not to do now...then spill the beans puhleeze.
AXA
Sep 5, 2015 10:06 AM
