fuel ecu requirement
Old Jul 2, 2003 | 03:29 PM
jdmConversion's Avatar
How many and what kind of modifications put on the FD's would require a fuel computer of some sort? im worry because with a certain amount of mods and no fuel computer can result in running too lean and engine detonation. im new to this forum so any help would be much appreciated.
Old Jul 2, 2003 | 04:00 PM
rynberg's Avatar
Welcome to the forum. Please use the search function and read through the sites listed in the newbie sticky. Once you've spent dozens of hours reading through those, THEN come and ask questions.
Old Jul 2, 2003 | 04:08 PM
maxpesce's Avatar
Ex fd *****
What rynberg said
But the rule of thumb is 3 mods (chosse 3 from Intake, IC, DP, & Catback) at STOCK BOOST (10psi) is OK. The stock IC or Intake and Cat cause enough restriction to keep you safe at stock boost. adding a MidPipe, Porting, or More Boost will put into the need more fuel zone.
Old Jul 2, 2003 | 05:26 PM
kyle@insight's Avatar
Dont like it? I dont care
So many ecu questions today
Anything beyond a downpipe I'd upgrade the ECU, that's probably being overly paranoid tho. Better safe than sorry tho.
Old Jul 3, 2003 | 12:20 AM
1 BAD 7's Avatar
Love ya, pops!
If I could go back and do it all over again, I'd say upgrade the ECU first or second, then go from there.
I blew my motor with just an intake and a DP - lasted three weeks, then *pop*
And of course...get a boost gauge before anything else
Old Jul 9, 2003 | 12:49 AM
a performance shop i called told me that a bigger fuel pump can also remedy the lean problem. is that true???
Old Jul 9, 2003 | 12:53 AM
The fuel pump won't help you if your ECU isn't using it to send more fuel. Talk to a rotary specialist shop, a normal performance shop wont cut the mustard.
Queppa
Nov 18, 2024 03:47 AM
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
